RS13 wrote:BZG|bling, thanks anyway man, but at this stage I'm putting the amp in the boot with the sub.
Not sure on the other things, its' the same as this one:
http://www.trademe.co.nz/Trade-Me-Motor ... 064197.htm
If I'm underdriving that sub, then what rating sub do you recommend? 1000W? Am I better off with a 10"?
I don't want too much of a horrible rumble, I want clean, punchy bass. I'm sure I've seen those 222W sony amps drive a 12"? Argh I dunno.
What would the sound quality be like with an underdriven sub?
Subway wrote:RS13 wrote:BZG|bling, thanks anyway man, but at this stage I'm putting the amp in the boot with the sub.
that amp would be lucky to hit 80wrms id imagine, not really even worth putting in your car IMO
RS13 wrote:
RMS bridged power @ 4 Ohm is 170W.
If it was that sh*t, then why is it pretty much only sold in a package with a 1300W sub?
Can someone just tell me what size and wattage rating sub to get that would make the best out of my amp?
method wrote:I have a tsunami 0/1ga kit for sale if you want
Because they are lying to you. They would rather rate a piece of equipment high on bullshiz parameters like PMPO or maximum output and boost your ego rather than letting you make an educated choice in spending your money.
If that amp does push out 170Wrms @ 4 ohm, then you would ideally want a sub that operates at 200Wrms with a single 4 ohm coil.
Even better would be a sub that is rated at 150Wrms @ 4 ohms because that way you would have overhead.
