ATTN Wgtn Toyspeeders! Urgent Help needed!
Postby .:O4AGTZ:. » Fri Oct 03, 2008 12:45 pm
ok well im half way thru changing my front brake pads on my levin. put th new pads in, pushed pistons all the way back in, and then went to put the calliper back over the top and it seems very tight! im not sure how tight it is meant to be tho. any ideas? also if anyone in wellington has nothing to do tonite please come help! ill reimburse ya with a bottle of jim beam that i have a feeling im never gonna drink. have to drive to work 2mrw but have no car!
.:O4AGTZ:.
Postby Distrb » Fri Oct 03, 2008 1:02 pm
where in wgtn are you?
Distrb
Regular Poster
Postby pc » Fri Oct 03, 2008 5:22 pm
Push the piston back further.
Are the brakes modified? different rotor or calipers?
A quick measure of the distance across the thickness of the pads and rotor will tell you if the caliper *can* go on.
Make sure the rotor is sitting on the hub flat when trying to put the caliper on, if you can't hold it flat, put a couple of wheel nuts on to hold it there.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby rollaholic » Fri Oct 03, 2008 6:07 pm
worst come to worse you can put old pads back in and drive to garage!
Postby AE82 FXGT » Fri Oct 03, 2008 6:10 pm
As above
1)make sure they are the right pads
2)make sure pistons/piston are right back
3)make sure any bolts or sliders aren't fouling
4)make sure the rotor is seated on the hub right, as having it on a slight angle will spread the pads making it harder
As a last resort, ditch any shims on the backing (if you have any), I've found sometimes that some aftermarket pads don't have the clearance for the shims from factory.
AE82 FXGT
Postby .:O4AGTZ:. » Fri Oct 03, 2008 6:16 pm
thanks for the input guys but i think iv found th problem! the top one of the two sliding bolts is siezed and not moving at all. tried everything. would also explain why only the inside pad is worn i guess. so sounds like im gonna need a new caliper cradle thing. anyone got a ae101 superstrut front left calliper cradle for a gtz? ill put it in the part section. any ideas to loosen the sliding bolt on the one that on there now?
.:O4AGTZ:.
Postby .:O4AGTZ:. » Fri Oct 03, 2008 6:30 pm
oh in reply to Distrb im in Te Marua. So if anyone has any ideas on how to free this sliding bolt feel free to have a try!
.:O4AGTZ:.
Postby gepsk8 » Fri Oct 03, 2008 6:55 pm
know man for job but he like cash only, text me if interested
O272754663
gepsk8
Postby .:O4AGTZ:. » Fri Oct 03, 2008 8:49 pm
dont worry guys got it sorted. mate who is nearly finished his apprenticeship came over and was like "man this is like goin back to kindy!" obviously proving my lack of knowledge. Managed to get the whole pin out, clean it, grease it up and put it back in and now we are all go!
.:O4AGTZ:.
Postby tsoob » Sat Oct 04, 2008 10:14 am
hey if your never gonna drink it ill take it off ya hands :lol: :lol: :lol:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby .:O4AGTZ:. » Sat Oct 04, 2008 6:43 pm
haha well after the end of this week i think ill be takin it off my own hands! gotta have something to make the rugby more interesting tonite.
.:O4AGTZ:.
Postby flygt4 » Sat Oct 04, 2008 8:56 pm
bugger i didnt see this earlier, I could have helped you, i've had the exact same issue before, and i'm just down in Timberlea. I even have half a caliper rebuild kit in my garage , enuf to do one side as i couldnt be bothered doing both..
the slides get full of crap and jammed up, you just need to strip them down and clean them out,usually replace the seal and boot while its apart and put some new grease in, like new.
flygt4
Postby .:O4AGTZ:. » Tue Oct 07, 2008 3:05 pm
yup thats pretty much what we did. noticed one of th discs is a tiny bit scored tho so im getting that skimmed off later in the week
.:O4AGTZ:.
Postby tsoob » Wed Oct 08, 2008 8:40 am
.:O4AGTZ:. wrote:haha well after the end of this week i think ill be takin it off my own hands! gotta have something to make the rugby more interesting tonite.
hard its $&#$% boring if ya aint drunk ha
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
