Most dumb thing / worst thing youve done to a car
Postby Mr Revhead » Mon Oct 20, 2008 8:17 pm
TOO
not IN
:P
Postby RollaGT_87 » Mon Oct 20, 2008 8:24 pm
Decided "If this car can't make it around this corner at this speed in the dry, I don't want it"... Now I don't have it :( Cressidas on standard springs are NOT epic grip machines!!
Tip for successfull rally driving: Don't sink you're car in the first pond to catch your eye.
"That's a f**kin' b*gg*r innit??"
"We were a bit hot, thought we'd take a dip n cool off"
RollaGT_87
Postby method » Mon Oct 20, 2008 10:41 pm
Saw a little rust bubble under the paint and poked at it with my keys... Ended up taking a 200mm by 15mm bit of steel out.. completely rusted through haha.
Same thing happened on the chassis rail of one of my cars! So badly rusted just covered up with a bit of underseal. But all the steel behind had rusted right through but was being held in place by underseal.
PICS UPDATED DAILY
method
Postby try_hard » Mon Oct 20, 2008 10:57 pm
i once wired in my sterio direct to the battery and left the wire to the battery sitting on top of the head. and when driving down the road it burst into flames.. dirty black smoke every were
AE92 Trueno Sprinter 4AGZE
try_hard
Postby MrOizo » Mon Oct 20, 2008 11:00 pm
When i turbo'd my AW11 i thought.. oh just a run around the block would have been fun...
only thing is i didnt have timing right (too advanced), no extra fuel, no IC, no.... ummm was something else, on a T3 from skyline. boosted awesomes!
Was one of the best and worst moments ever with the car :)
If only i had done the things i was meant to, it might have survived nore than 10 mins :P
Nuty|Mike knows all about it :D:D:D
MrOizo
Toyspeed Legend
Postby skoty » Mon Oct 20, 2008 11:05 pm
Rewired my cars alternator without the voltage regulator (had an external one) Wiring harness caught fire, didn't know what that black box did back when I first started playing with cars :lol:
skoty
Postby RomanV » Mon Oct 20, 2008 11:11 pm
Engine not starting after an engine swap, after weeks of trying to figure out what the hell was going on, started pulling the motor back out.
Found that one of the earth wires was tucked up under the intake manifold, instead of bolted to the block. Engine fired up after that, buuuuutt.....
Set the cam timing to the wrong mark, engine backfired out the intake and blew up my apexi pod filter. Engine/gbox back out to fix it.
Then the engine was going, temperature stable, etc etc. Put the car in reverse and CCCRRRRUUUNNNCCHHH BRRRRRR
Note to self: 3SGTE and 3SGE input shaft diameters are not the same.
Checking spline diameter before wrecking an expensive cusco clutch is advisable. Motor/gbox back out, spline on clutch rounded off.
Decided to put in my other motor, so got a new light weight flywheel & exedy clutch to suit 3SGE box.Then used an allen key to tighten clutch cover bolts, which eventually came loose of course. Engine/gbox back out to fix it.
Then my clutch blew up, and I thought "$&#$% this shit" and parted out the car. :o
Having a car that takes an hour to get the motor in or out suits my 'special needs' more than with MR2 that takes me a week or so every time I do something retarded. :lol:
Ahhhh, it's all a learning process I guess, not *quite* such a noob these days thankfully.
Postby frost » Tue Oct 21, 2008 12:52 am
not me but a friend, but still funny and dumb,
she is blond to say the least, she asked me why there was no water squirting out when she wanted to clean the windscreen, i said open the bonnet and fill the washer bottle with water,
15minuts later i get a phone call asking why her car would not start :roll: get over there and she filled the MOTOR to the brim with water!!!! :lol:
Postby Leon » Tue Oct 21, 2008 6:35 am
I bought a Fiat Uno. That is the stupidest thing I've ever done with a vehicle.
Postby Lloyd » Tue Oct 21, 2008 7:09 am
Boosted_162 wrote:I mostly forget to disconnect the battery when doing stuff, nearly caught my ST162 on fire while swapping gearboxes :lol:
Could be worse. I know a guy who just got out of hospital due to removing a fuel pump from a tank with the battery disconnected and the key on. Wreckers lol
Postby Timmo » Tue Oct 21, 2008 8:36 am
Dash lights stopped working after cleaning my interior, so checked all fuses, took dash cluster out, checked bulbs, checked connections etc etc....Put it back together and still didnt work!
Went and had a bite to eat.....came back and turned up the Dash light dimmer switch.
DUH! :roll:
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby 1I1 » Tue Oct 21, 2008 9:05 am
Rust bubble on A-pillar of my old ex lancer. Decided to press against it and then crack - a nice hole in what should have been metal but thanks to 20-something years of corrosion it was more rust than metal. Couple hundred dollars later and i had a nice professional repair
TRD Clicky >>Here
1I1
Postby DeeCee » Tue Oct 21, 2008 10:11 am
Leon wrote:I bought a Fiat Uno. That is the stupidest thing I've ever done with a vehicle.
I've had one Fiat Uno, 2 Fiat Pandas and a Lada Niva...
Worse thing I did was to paint my old celica, but only got half way through lol
GT Four Adovansu
DeeCee
Postby pjay » Tue Oct 21, 2008 10:55 am
wired the GTZ's ABS light to the engine check light so it wouldnt stay on for wof
pjay
Postby Snaps » Tue Oct 21, 2008 11:20 am
frost wrote:not me but a friend, but still funny and dumb,
*facepalm*
I haven't done anything stupid on a car....yet, but I'm learning a lot from this thread lol.
Cheers,
Brandon
Snaps
Postby rolla_fxgt » Tue Oct 21, 2008 12:03 pm
Took my fxgt padock bashing/boot racing in central otago, was really fun, untill I found a huge lump of schist rock (that i swear wasn't there 5 mins before) at speed of a jump with the passengers foot well.
Not cool after you've just got the car.
Though luckily no major damage, just bashed it back out with a hammer, still a bit of a lump there though.
I now drive slower off road, or use someone else's car with slightly higher ground clearance.
Except that time we took a mates AW11 down the Wanaka Lake outlet track after the sign that says 4wd only, it only bottomed about 6 times, lucky there so light to move
rolla_fxgt
Postby touge rolla » Tue Oct 21, 2008 4:06 pm
Selling my MA61 :cry:
(though that could have also been the smartest thing I've ever done too? These cars seem to take forever to fix up :lol: )
touge rolla
Postby Emperor » Tue Oct 21, 2008 5:00 pm
Timmo wrote:Dash lights stopped working after cleaning my interior, so checked all fuses, took dash cluster out, checked bulbs, checked connections etc etc....Put it back together and still didnt work!
DUH! :roll:
Not as bad as when I was freaking out wonderin why my windows wont go up... spent a few hours ringin people and shit.
Turned out the window lock was on!! hahahaah
Emperor
Postby mjrstar » Tue Oct 21, 2008 6:42 pm
i once purchased an oil pressure gauge with a plastic hose... i won't be doing that agin...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby bs » Tue Oct 21, 2008 6:51 pm
Trying to get Gizzmo shift light working. Had it hooked up to number one cylinder and yes i got zaped wile the car was running. Ended up going to the ecu to wire it in.
bs
Users browsing this forum: Bing [Bot] and 17 guests
