non toyota coolant leak.
Postby hsmidy » Sat Nov 01, 2008 6:44 pm
Hey so ill give you a run down, blow the head gasket in my 93 lancer with a 4g92 engine soch engine in it, sweet as replaced the headgasket etc and all new o-rings on everyting etc.
anyway theres a pipe that runs along the back of the engine under the intake manifold from behind the waterpump to the thermostate housing its a bit of a press fit and use's to rubber orings to seal it(which i replaced) long story short i put it all back together and its leaking past the oring that seals at the water pump end.
any ideas on how to seal it up ?
hsmidy
Postby Burning Angel » Sat Nov 01, 2008 7:12 pm
sounds like the housing where the o-ring seats is corroded a bit allowing water past.
i would probably smear a good dollop of loctite bluemaxx silicon around it an reassemble(bluemaxx has a high glycol resistance )
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby hsmidy » Sat Nov 01, 2008 8:54 pm
Yeah when i pulled it all apart it all looked pretty tidy aye and i gave it a clean up, after putting it back together and it leaking i tried sealing it up with some silocine(admittedly not the lotite stuff) and it still leaked.
hsmidy
Postby rollaholic » Sun Nov 02, 2008 7:15 pm
if its leaking around the O ring, something is not right - at a guess you used the wrong o ring, or its been twisted when you put it back together
shouldn't need silicone!
Postby hsmidy » Sun Nov 02, 2008 7:46 pm
nar o-ring is mint and it was identical to the one removed, i know it shouldnt need silicon but ya gotta try these things, i might try getting an oring with a larger outside diameter.
hsmidy
Postby JRS » Sun Nov 02, 2008 8:14 pm
smear rubber grease on the o-ring before pushing the pipe in. other wise the ring can roll out of it's groove.
meh.....
JRS
Postby hsmidy » Mon Nov 03, 2008 6:57 pm
tried that as well, plus its a pretty tight fit in the groove i highly doubt it would just roll out
hsmidy
Postby rollaholic » Mon Nov 03, 2008 8:33 pm
perhaps the pipe is not sitting squarely into the back of the waterpump, are any of the tabs that hold it to the block bent or anything?
