ae101 trouble; stumped!
Postby FULLOC » Tue Nov 04, 2008 4:22 pm
hey was driving home today and the levin all of a sudden crapped out, kept running but engine light on fulltime and wont idle unless held at decent rpm and is running like it in limp mode or something
i got home, some 80km later at 60kph and tried to run the diagnostics but it wont give me any codes. im sure im doin it correctly, e1 to te1, even tried e1 to te2.
basically runs ok, no noises or knocks or anything but is lightly blowin some black fumes (runnin rich mayb?), doesnt like driving over 3000rpm, even thats a struggle but will rev to redline ok jus sounds a bit off.
i unplugged knock sensor but no change
have disconnected battery
and ecu fuses
and efi fuse which is supposed to reset codes.
has good spark and too much fuel if anything so in think its in limp mode or somthing
any gurus out there?? please the missus is drivin me f-n crazy
FULLOC
Postby johndoe1025 » Tue Nov 04, 2008 5:44 pm
sounds like u may have jumped a tooth on your cambelt?
johndoe1025
Postby AceSniper » Tue Nov 04, 2008 6:17 pm
sounds very much like crapped out capacitors in the ecu.... can solder new ones in from dse
AceSniper
Postby Crucible » Tue Nov 04, 2008 9:51 pm
yep if its not giving fault codes the ecu is poked!, I recently had the same symptoms you had, hard starting, idle but wont rev, really rich!.
the check lamp was on but when i bridged it wouldnt flash, put a new ecu in and check lamp out, back to normal :)
Crucible
Real Life Mechanic
Postby FULLOC » Tue Nov 04, 2008 10:02 pm
cool cheers guys.
figured it was somethin like that, jus been searchin on the net. limp mode drops timing right back so would explain why it feels like the timings out.
ecu behind the glovebox like usual?found the heater and shit but havent ripped anythin apart yet.
will get onto it tomorrow :D
if anyone in hamilton or nearby has an ecu i can try it would be appreciated.
FULLOC
Postby 85AW20v » Tue Nov 04, 2008 10:09 pm
ECU is probably on top of the tunnel under the heater. Access from drivers side I think....
See ya
Simon
85 MR2 20v
85AW20v
Postby MR2SIK » Tue Nov 04, 2008 10:22 pm
can access from either side, I just went right through the middle in my brothers car lol
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby .:O4AGTZ:. » Wed Nov 05, 2008 2:47 pm
yea sounds very similar to what happened to my gtz, went into limp mode and wouldn rev over 3000rpm etc and threw up no codes at all. but now it has all of a sudden gone! didnt drive it for like a week and jumped in it and nothin is wrong...
.:O4AGTZ:.
Postby FULLOC » Wed Nov 05, 2008 5:24 pm
Pulled ecu out and inspected it. cant see a single thing out of place and all looks very clean and non-leaky.
Will try buy a new ecu 2moro, u sure if i cant get codes it is the ecu??
FULLOC
Postby AceSniper » Wed Nov 05, 2008 10:43 pm
just replace the capacitors then you will know if its the ecu or not... its cheap todo... buying another ecu may have the same issue... over half the 20v ecus iv looked at have been leaky... or non leaky but problem solved when caps replaced
AceSniper
Postby Crucible » Wed Nov 05, 2008 11:31 pm
FULLOC wrote:Will try buy a new ecu 2moro, u sure if i cant get codes it is the ecu??
thats what our sparky said when I couldnt get codes out, i had brought car with stuffed motor put another motor in, got it running check lamp was on and ran like a bag of sh*t, the air temp sensor was missing so thought it was that but he said doesnt normally blip check lamp with toyotas.
since i couldnt get codes out i was pretty much stuffed as to what was up, ecu gives out the codes anyway so plugged in another map 4agze ecu and it was sweet.
yea he reckons capacitors were faulty aswell!
Crucible
Real Life Mechanic
Postby johndoe1025 » Thu Nov 06, 2008 5:45 pm
could be your VVT, tlked to a guy at work, if its jammed it will come up with the light, MEGA retard your timing, and probably not log a code. so if the next ECU doesnt help you, id be looking there. i drove a ae101 witht he exact same symptoms as your sayying and when i asked about it it iwas suggested that it was a vvt fault
johndoe1025
Postby FULLOC » Thu Nov 06, 2008 7:37 pm
Hey thanks alot for all the help guys, new ecu sorted the problem right out. dunno if it was capacitors or not as both ecu's looked in mint condition. i might try repair the old one one day.
FULLOC
