Ae101 warning light
Ae101 warning light
Postby thornz » Tue Sep 09, 2008 12:39 pm
Have just had a warning light on the dash come up, its is the very bottom on on the left, shows a picture of a car with lines coming out each side of the rear like a exhaust fumes?????? Anybody know what this one means?
thornz
Postby AE82 FXGT » Tue Sep 09, 2008 1:33 pm
Not brake light out warning is it?
AE82 FXGT
Postby 2LTR Rona » Tue Sep 09, 2008 2:59 pm
yeah its the light warning indicator.
will show if a bulb is blown (if i remember correctly) but will also show up the wrong voltage of bulb is put in as well.
2002 Altezza, 1974 KE25
2LTR Rona
Postby thornz » Tue Sep 09, 2008 3:29 pm
Ahh, thats make more sense, will check it out tonight.
thornz
Postby thornz » Thu Nov 06, 2008 9:03 am
Okay, I know I posted this a while ago, but never got round to checking it out till yesterday as I haven't been driving the car much, and the WOF is due next week. Have checked all the lights, and they still work, would be odd if its the wrong voltage bulb, as none of them have been changed in my ownership.
Is it likely to fail the warrant for having the warning light on the dash if nothing actually seems wrong with car?
Also, the handbrake light keeps coming on intermittently when just driving along, any suggestions?
thornz
Postby Leon » Thu Nov 06, 2008 9:09 am
In theory yes it could be a fail
8-1-4 braking system, reason for rejection
"34. The ABS, or brake system warning lamp or self check system, if fitted indicates a defect in the ABS of brake system (does not apply to brake pad wear lining systems)."
Postby thornz » Thu Nov 06, 2008 9:13 am
The car doesnt have ABS, so it should be anything to do with a ABS system. :D
thornz
Postby 2LTR Rona » Thu Nov 06, 2008 9:21 am
thornz wrote:Is it likely to fail the warrant for having the warning light on the dash if nothing actually seems wrong with car?
yes you "could" be failed as I have come across this myself, different voltage bulbs in the rear tail lights. Depends on how hard the WoF man wants to be I guess.
Hand brake light comming on could be a sign of needing adjustment, might be a wee bit too tight and grabbing the disc as it rotates. I'd pull the rear apart and take a look at clearances etc.
2LTR Rona
Postby Leon » Thu Nov 06, 2008 9:23 am
That kind of captures pretty much everything related to brakes and warning lights though. If the guy cares that is. :lol:
Postby thornz » Thu Nov 06, 2008 9:32 am
Well, I'm going to send it through today and see how I get on. :?
thornz
Postby Leon » Thu Nov 06, 2008 9:34 am
Pretty much about the only way you are going to find out
Postby thornz » Thu Nov 06, 2008 9:36 am
Cheers for your help guys, will post up the outcome.
thornz
Postby thornz » Thu Nov 06, 2008 11:49 am
Well passed the warrant, one of the brake light bulbs was blown, but seeings as there are two brake lights on each side, and only one is requires, I still passed. So stoked with that, apart from I think I need my eyes testing :lol:
One thing they did mention is that teh CV boots are split, doesnt affect the warrant either, but keen to get them fixed. How hard a job is it to do yoruself?
thornz
Postby 20v_rollaboy » Thu Nov 06, 2008 12:04 pm
Inner or outer cv boot? From memory the inner ones are easy to do, and the outers not so easy
20v_rollaboy
Postby RS13 » Thu Nov 06, 2008 4:42 pm
thornz wrote:Also, the handbrake light keeps coming on intermittently when just driving along, any suggestions?
Brake fluid will be low in the reservoir. When you hit a bump, the low fluid warning light will flicker, if you ignore it the light will eventually stay on.
RS13
Postby matt dunn » Thu Nov 06, 2008 11:25 pm
Surprised it took someone that long to point it out.
First thing we ever do when a customers car comes in saying the handbrake light flashes or wont go off is pop the bonnet and check the fluid level.
Your brake pads are low and the fluid has gone from the master cylinder,
into the slave cylinders, and the fluid is low bringing on the light.
The fluid resovior is capacity matched to the brakes so that it comes one a long way before the pads are really worn out, but that's the theroy.
