by Twolitre » Sun Nov 09, 2008 9:10 pm
You need to find out exactly where it is leaking as you don't want to end up on a wild goose chase, High pressure power steering hoses off the pump often leak and can be rebuilt by hydralink.
I bought a pump rebuild kit from toyota a few years back and got a power steering specialist to install it however I'm sure there are cheaper options depending on how mechanically comptetent you are.
