gearbox suggestions > 1uz
Postby lucasthefallen » Thu Nov 13, 2008 8:35 pm
right well i am hearing different advice from all over the show, basically i want a manual g/box to use with a 1uz, im either using r150 or w57.
engine will be standard apart from some match porting and possibly a different intake manifold.
reasons against the w57 is it wont be strong enough for long enough
and issues with the r150 is the shear size of the damn thing.
please any advice is valued, also i need to know what model each of these g/box's can be found in.
and if anyones interested plans are to put it into a kp6# starlet
Need Service or Repair work done? send me a PM
lucasthefallen
Postby gepsk8 » Thu Nov 13, 2008 8:50 pm
what u gona be doing in it?
it how u drive? i know a guy with w55 behind 1uzfe skidds crap out of it, in hilux, never had a problem.
O272754663
gepsk8
Postby lucasthefallen » Thu Nov 13, 2008 9:13 pm
will be a fun car for track days, road legal. will be getting a very hard time, heaps of skids and thrashing the shite out of it
lucasthefallen
Postby gepsk8 » Thu Nov 13, 2008 9:18 pm
spend the money the first time, get r series then out of new hilux or something, then u will never have to many issues
O272754663
gepsk8
Postby evil_si » Thu Nov 13, 2008 10:33 pm
check out lextreme.com
a w box will be sweet
evil_si
Postby deaf_rattle » Thu Nov 13, 2008 10:35 pm
id go 300zx manual box. :wink:
Postby escortman » Thu Nov 13, 2008 10:49 pm
deaf_rattle wrote:id go 300zx manual box. :wink:
eww theyr just a gt25t box there tiny as :wink:
although was reading a mag from oz and in the tech section the guy said the r15* boxs are weak as so i vowed never to buy a oz mag again (off topic sorry)
4x4 toyota blizzard offroader
escortman
Postby deaf_rattle » Fri Nov 14, 2008 6:07 am
plenty of high hp 1uzs using them though, they can handle the torque.
Postby escortman » Fri Nov 14, 2008 6:46 am
the gt25t or supra box? both can take it fine,
escortman
Postby soopachargen » Fri Nov 14, 2008 2:14 pm
you wouldnt get enough tyre under the rear of a starlet to do much damage to a box would you? wouldnt the torque just turn into tyre smoke?
When in doubt, down and out.
soopachargen
Postby QikStarlie » Fri Nov 14, 2008 2:50 pm
as above. dout you will have any issues with a w55 if its a stock 1uz in a kp.
QikStarlie
Postby MrDori » Fri Nov 14, 2008 7:04 pm
I run a w57 in behind my 1uz, mild mods, Kane the shit out of it at drift days no issues at all.
Engines arnt hugely grunty unless you give em boost.
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby lucasthefallen » Fri Nov 14, 2008 7:45 pm
i'll probably look at cutting the wheel wells out bigger to fit wider tyres at a later date.
also will look at the m90 charger at some stage too.
biggest concern at the moment is getting her all mounted and running
lucasthefallen
Postby evil_si » Fri Nov 14, 2008 9:30 pm
i have 245's for my ute,
and i have supercharged my 1uz with a m90, i intend to run a w57,
plenty of guys around the world running w series behind 1uz's with boost,
evil_si
Postby BlakeNZ » Sat Nov 15, 2008 10:54 am
mate the z32 300zx box is really big, and strong as!
i reckon the w58 is a good bet- it will handle all the power an atmo 1uz can muster.
BlakeNZ
