Reinventing the wheel is not a cheap option
True-No-Turbo wrote:yeah would have to be a fair bit more than 200kw to break traction in 3rd, I could get my trueno to let go when cornering if i kicked the clutch in dry but theres no way itll spin through 3rd from 2nd or spin in 3rd when coming on boost.
in the wet is a differant story though
escortman wrote:yeh go td05, ae111 with blacktop head ze bottom and td05 had over 200kws its the silver 1 on trademe, im running a td05 20g rated for similar power to the t3t4s cept comes on way sooner a lot more driveable
~SlideWays~ wrote:escortman wrote:yeh go td05, ae111 with blacktop head ze bottom and td05 had over 200kws its the silver 1 on trademe, im running a td05 20g rated for similar power to the t3t4s cept comes on way sooner a lot more driveable
My t3/04e is amazingly responsive for the size the the thing. Spool and responsiveness will come down to a lot of things like compression ratio, ign timing, fueling, manifold design, intercooler size, plumbing etc etc
My old 4agte with 8:1 pistons, bigport head (with TVIS running thru Link+) and GT28RS (ball bearing) only spooled 500rpm earlier than the new setup of 8.9:1, smallport head, new tune and T3/04e (plain bearing).
Also I find that a boost plot from the dyno isn't a good indication on what it'll actually be like to drive. I know of a 4agte with t3/4 that struggled to get boost in 1st and would drop off boost changing up to 2nd vs mine where it spools in 1st really easy and a lazy change up will still be on boost.
xsspeed wrote:Mean procharger!
Good effort I say, any idea yet how well it spools etc?
