Lowering Spring Advice.
Postby headshotnz » Mon Nov 24, 2008 6:08 pm
Hey guys, (and girls :P)
I have a AE100 toyota sprinter 94 LX.
It has 17" wheels on it and looks like a should by four-wheel driving.
I'm going to lower it this summer hopefuly, my plan is to get some monroe shocks. But i dont know what springs I would like to get.
I'm not looking for a "super-low" look. More or less, im wanting the stiffest ride possible, (I hate body roll :()
Jamex has cheap springs on TM, but i beleive there not very soft. I dont really know that much about other brands, Also im not wanting to spend much, mabey 400/500 etc. (not including shocks.)
I also dont know were to buy TRD springs from, they may be good?
Any way, any advice would be great :)
headshotnz
Postby Bling » Mon Nov 24, 2008 7:07 pm
I'd probably go down this path.
Buy new GENUINE Toyota shocks
Buy TRD springs.25-35mm drop most likely - they won't drop 50mm if thats your plan.
Good result for reasonable money.
Check the sponsors section, we have someone that supplies us with Toyota / TRD parts a good rates.
However, in my car I went Cobra springs and KYB shocks. If I was buying again though I would go with my above choice and stay Toyota bits. Monroe shocks seem to get bad comments, not great performance and don't last all that long. (just what i've read). KYB have a good name, better than Monroes.
If you're after 50mm drop, theres a few options for springs, all probably much of a muchness for your car. Cobra, Kings, Jamex etc
Re: Lowering Spring Advice.
Postby ee904age » Mon Nov 24, 2008 7:07 pm
Toyota?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby phoenix » Mon Nov 24, 2008 7:30 pm
I had Jamexs in an ST202 and they were too soft. Hit the bumpstops a fair bit. I'd go king springs low (300-400?) or TRDs (600?)
phoenix
Postby headshotnz » Mon Nov 24, 2008 8:53 pm
BZG|Bling wrote:I'd probably go down this path.
Cheers mate, ill look into that, I'm just abit worried on the prices of TRD stuff. But cheers for the info, ill go have a look :)
ee904age wrote:
Toyota?
Sorry, i ment to soft. I went on the toyota site and it just points to the .jp site with model numbers and what not.
phoenix wrote:I had Jamexs in an ST202 and they were too soft. Hit the bumpstops a fair bit. I'd go king springs low (300-400?) or TRDs (600?)
Yeah thats what i got told. cheers mate.
Also, im not to worried about a huge drop, mabey in the back.
But im more looking for a "stiffer" ride.
headshotnz
Postby johndoe1025 » Mon Nov 24, 2008 9:07 pm
i got jamexes in my levin, harder than factory, but still not very hard to bottom out. my rear shocks were stuffed, stuck KYB's in and omg what a difference, no longer could i jst step off the gas mid corner and slide the tail out, the car now sticks to the road like glue. and i got shitty tires. i always buy kyb shocks, had them in my starlet too
johndoe1025
Postby headshotnz » Mon Nov 24, 2008 10:11 pm
johndoe1025 wrote:i got jamexes in my levin, harder than factory, but still not very hard to bottom out. my rear shocks were stuffed, stuck KYB's in and omg what a difference, no longer could i jst step off the gas mid corner and slide the tail out, the car now sticks to the road like glue. and i got shitty tires. i always buy kyb shocks, had them in my starlet too
Yeah, my stock ones bottom out a little.
What would a set of KYB's set me back roughly?
headshotnz
Postby Mr Revhead » Mon Nov 24, 2008 10:25 pm
BZG|Bling wrote:Monroe shocks seem to get bad comments, not great performance and don't last all that long.
monroes have a longer warranty than genuine :wink:
the monroes stocked for that model in nz will be fine
a 50mm drop is quite a lot for an ae100 series car, they are quite low underneath, so make sure it will still be legal as superlows are often under 100mm minimum height on those cars.
you maybe able to get 50mm lower springs from king, the problem is king springs are average quality at best.
youd be better off with cobras or dobis, im pretty sure cobra have a superlow and dobi also list one, though i think its more 40mm than 50mm
