toyodiy.com
toyodiy.com
Postby xsspeed » Tue Oct 14, 2008 10:30 am
Hey guys,
Don't know if I'm just slow but have seen a couple of posts re the toyodiy.com site.
Who uses it?
Are the part numbers accurate?
I have found that in my parts book for my corolla (essentially the same as the EPC on this site) the part numbers dont necessarily correlate to the number on the part itself. (Found this was the case on the headlights) Is this because its the catelogue number?
Or is there different numbering systems depending on country or something like that?
Postby soopachargen » Tue Oct 14, 2008 1:08 pm
wholey fook that is sooo cool, but yes, is it accurate?
When in doubt, down and out.
soopachargen
Postby postfach » Tue Oct 14, 2008 3:10 pm
there must be different part numbers for different countries/regions, otherwise they wouldn't have the option in there
postfach
Postby xsspeed » Tue Oct 14, 2008 3:18 pm
Ok true, then is there a difference between catelogue number and the number stamped on the part?
These are the codes given for the RH headlight 81135-1A180 or 81130-1A182, but stamped on them is 12-234R or something like that
Postby Jdawg » Tue Oct 14, 2008 3:31 pm
If it is a part catalogue from USA they drive on other side of road so headlight needs to be different.
There are probably a few other areas that are different due to countries regulations.
Jdawg
Postby xsspeed » Tue Oct 14, 2008 3:34 pm
Nah it was for general countries - RHD vehicles
Postby soopachargen » Tue Oct 14, 2008 8:14 pm
xsspeed wrote:Ok true, then is there a difference between catelogue number and the number stamped on the part?
the 81135-1A180 is the toyota part number, and the 12-234R is the lense number
soopachargen
Postby MasCam » Tue Nov 25, 2008 5:30 pm
Had a chance to test this today and for my Jap import car it seems accurate.
The only problem that I can see is working out which of some of the optional bits are the one's your specific car is equipped with (In the case I looked at one of several different diffs)
On some other bits it is defiantly accurate.
Chris
MasCam
Postby AE86less » Tue Nov 25, 2008 6:20 pm
I don't trust it.
Tried looking up an 86 FXGT and got asked if it was a 1600cc, 16 valve turbo :?
Then all the engine/drivetrain diagrams for the ST202 showed a 4wd turbo.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AE82 FXGT » Tue Nov 25, 2008 9:36 pm
I think it's quite good, looking at my reciepts and matching part numbers has been good.
It's also great if it been a while since you pulled something apart and sorta forgot how it goes :oops:
AE82less - found what you're talking about, but ry to find the turbo in the catalogue... I think it's a typo.
AE82 FXGT
Postby AE86less » Tue Nov 25, 2008 11:49 pm
:o AE86less!
It just seems weird. Why does it have ST205 Diagrams for the ST202?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AE82 FXGT » Tue Dec 16, 2008 12:48 pm
haha, my bad, my head was elsewhere.
I think it's useful, but I will want to double check part numbers before rattling them off to a dealer.
Good for reference too.
(I get how someone can be ae86less, any chump can buy an ae82 haha)
AE82 FXGT
Postby MercuryFree » Tue Dec 16, 2008 11:47 pm
AE86less wrote::o AE86less!
Hah, fully didn't notice that. Have used it to order curren lights and checked it against celica parts i've bought from toyota and the part numbers do match up however
MercuryFree
Postby Outlander » Sat Jan 10, 2009 11:51 pm
This seems pretty cool, should be mad when it gets fully up and running.
Outlander
