ae101 trueno dashboard warning lights
Postby h8wrxs » Mon Nov 17, 2008 7:15 pm
i got a problem
one of my warning lights has come on in the past few days and i cant figure out what it is
its the bottom wanring light under the engine light and its shaped like a car with rear lights on if that makes sense.
i was thinking it would be a blown bulb or something but all the bulbs on the car are mint?
any help would be appreciated
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby AE82 FXGT » Mon Nov 17, 2008 7:17 pm
Be blown bulb or wrong wattage bulb
AE82 FXGT
Postby johndoe1025 » Mon Nov 17, 2008 8:04 pm
does it come on when the car starts up? the light usually only comes on when the set of lights used have a fault. eg if you got a brake light out, as soon as you touch the brakes, the light will come on
johndoe1025
Postby thornz » Mon Nov 17, 2008 8:30 pm
Yip, itll be one of your brake lights, I had this issue not long ago. Theres a thread a bit further down about.
thornz
Postby trd_chik » Mon Nov 17, 2008 8:57 pm
yer itll be one of ur brake lights out, get sum1 2 check them 4 ya so u know which one it is, i had that problem not long ago mine was just that the spoiler light wasnt plugges in properly lol. so just check that ur bulbs havent blown and if its not that may be loose wiring
trd_chik
Postby h8wrxs » Sun Nov 30, 2008 5:11 pm
yeah, the tail lights are fine, no blown bulbs
ive just recently had the car resprayed and had the spoiler removed but ive put a high mount lamp in the back window and that works fine as well??
oh well its obviously not a terribly bad thing then.
cheers anyways
h8wrxs
Postby rollaholic » Sun Nov 30, 2008 5:50 pm
sounds like whoever put the high stop in used a feed from either the left or right brake light, and left the wiring for the old highstop in the spoiler hanging somewhere. probly need to bridge two of those, the place that removed the spoiler should have done this!
Postby h8wrxs » Tue Dec 23, 2008 12:36 pm
nah i did it, and i used the wires from the old high stop light in the spoiler, just fed it back through to the parcel tray...?
h8wrxs
Postby 85AW20v » Thu Jan 01, 2009 4:35 pm
The dash light indicator works off the resistance in the circuit. If the new highstop is too much of a change from stock, then the dash light will come on. Don't ask me how you work out what it should be though!!
See ya
Simon
85 MR2 20v
85AW20v
