converting to individual coils?
Postby d1 mule » Sun Nov 30, 2008 5:41 pm
im just wongering whats involved in changing from dizzy to coil over plug setup on a 4age with a link??
reason being car wasnt running, so i put a "new" dizzy in, and it ran sweet as for about 5 mins now wont run again.
or would i just be better off getting a new ignition module for the dizzy??
i want the car to be ready for drift south on the 20th dec and practise on the 16th so am getting pretty anxious :?
d1 mule
Postby Flannelman » Sun Nov 30, 2008 6:20 pm
ive seen people use VR4 sender unit and coil packs. but you have to find them
Flannelman
formerly known as Affroman
Re: converting to individual coils?
Postby matt dunn » Sun Nov 30, 2008 6:40 pm
d1 mule wrote:or would i just be better off getting a new ignition module for the dizzy??
Probably better to fix what you have,
depending on the link version it may need to be re-configured,
you will need to run a GZE or smallport dist assy,
and will need to change wiring a bit, and then also get the coils leads and igniters etc etc.
Postby d1 mule » Sun Nov 30, 2008 8:23 pm
its a V5.
its just had a few ignition issues, done a coil and now 2 dizzys in about 5kms tops of driving (large ammount on the limiter tho, so im getting a bit frustrated
d1 mule
Postby matt dunn » Sun Nov 30, 2008 8:35 pm
d1 mule wrote:its a V5.
What do you mean by done a dist? they are not the sort of thing that wear out or you can damage easily? sounds like there are other problems to me.
Postby d1 mule » Sun Nov 30, 2008 9:12 pm
yeah my thoughts too. It was running after i put the new coil in, then died when i was driving it, put a new dizzy in today and it ran sweet as for about 5 mins and died again while it was idleing and wont go at all now.
iv got a autosparky mate checking the 1st dizzy out tomorro see if tis buggered.
d1 mule
Postby ChaosAD » Sun Nov 30, 2008 11:10 pm
If you do end up changing it. Go for mitsi wasted spark coils.
Individual coil-on-plug setups often fail from the heat
ChaosAD
Postby d1 mule » Mon Dec 01, 2008 7:36 pm
original dizzy tested fine today..... getting solder joints on the PCB tested tomrro hopefully its omethin easy like that
d1 mule
