supra torsen LSD?
supra torsen LSD?
Postby matt dunn » Sun Dec 14, 2008 2:57 pm
What model of supra come out with the torsen LSD rather than the plate type?
Think it was the JZA80 series?
and are they a G series diff?
If so what would the diff code be if I was looking for one?
Postby the fallen303 » Sun Dec 14, 2008 3:10 pm
i've got a torsen in my mk3, which run the G series. think the code ends in a 9? the plate lsds end in a 5, which is 4 pinion lsd. ie the 3.9 plate lsd that everyone usually gets is a g315 lsd.
true house of JZ
Stay true to the origin
the fallen303
Postby Snaps » Sun Dec 14, 2008 4:25 pm
Even *some* of the N/A MKIV supra's came with the Torsen LSD (Dunno about MKIII's) you can check mkiv.supras.org.nz under 'specifications' to see which ones did, and it also has the Number somewhere in something like the VIN plates, that site also shows that.
Cheers,
Brandon
Snaps
Postby postfach » Sun Dec 14, 2008 4:59 pm
MKIII G series torsen is G299.
postfach
Postby thegreatestben » Sun Dec 14, 2008 5:35 pm
postfach wrote:MKIII G series torsen is G299.
:P
thegreatestben
Postby MrOizo » Sun Dec 14, 2008 5:37 pm
This is for the Manual Supra, 4.11:1 (R154)
the G319 is also a torsen, one with Auto, 3.9:1 (A342E)
MrOizo
Toyspeed Legend
Postby matt dunn » Sun Dec 14, 2008 7:07 pm
So what is a G295 Supra one?
Postby postfach » Sun Dec 14, 2008 7:23 pm
I'm going to hazard a guess and say its a 4.1:1 clutch type lsd.
Do you want an entire diff or just the center?
postfach
Postby Py7h0n » Mon Dec 15, 2008 6:54 am
I've got a G series Torsen center if you are interested...
Py7h0n
Postby matt dunn » Mon Dec 15, 2008 11:43 pm
Py7h0n wrote:I've got a G series Torsen center if you are interested...
Yeah depending on what you want for it.
PM me.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
