Intake Manifold Runner lengths?
Postby cat007 » Sun Dec 14, 2008 8:19 pm
Hey,
Is there anyone on here who can help me out with intake runner lengths?
I'm in the process of making a manifold from scratch and not sure what length to make the runners. Does it matter that much on a turbo'd car?
Postby KinLoud » Sun Dec 14, 2008 9:28 pm
It does matter for both NA and turbo - don't believe the "air just get forced in" myth.
Look at the factory length for a turbo engine. Probably tuned for drivability so if you are looking for more power at higher revs maybe use 70 or 80% of the factory length
Ken
Auck
021 408 863
Postby Akane » Sun Dec 14, 2008 10:24 pm
I believe that the shorter the runners, the more high end power, while the longer are more torque. Ofcourse everything has to be tuned you can't just stick some pipe on to lengthen it.
Postby blackmk3 » Mon Dec 15, 2008 6:44 pm
Another thing to consider is volume, if its to big your going to loose alot of your air speed
Mk3 MA70 Supra
blackmk3
