1jzgte qns
1jzgte qns
Postby escortman » Tue Dec 16, 2008 7:41 pm
mate just put a 1jzgte out of mark 2 into his jzx100 chaser were wondering what the 2nd throttle bit is for as it has its own ecu but the chaser loom was no plugs for it
4x4 toyota blizzard offroader
escortman
Re: 1jzgte qns
Postby matt dunn » Tue Dec 16, 2008 7:50 pm
escortman wrote:mate just put a 1jzgte out of mark 2 into his jzx100 chaser were wondering what the 2nd throttle bit is for as it has its own ecu but the chaser loom was no plugs for it
traction control??
Postby flygt4 » Tue Dec 16, 2008 7:57 pm
i know the 2jz runs a 2nd throttle butterfly for traction control, sounds like a similar deal. i think most people rip it out.
flygt4
Postby escortman » Tue Dec 16, 2008 7:59 pm
ook sweet
escortman
Postby escortman » Sat Dec 20, 2008 5:41 pm
duno if this is to vague but its now running but idles at like 2,500 -3000 rpm no matter what any ideas?
escortman
Postby postfach » Sat Dec 20, 2008 6:40 pm
vacuum leak?
postfach
Postby escortman » Sun Dec 21, 2008 2:27 pm
yeh checked for them couldnt find anything dropped it off to the suprachics earlier so theyr gona have a suss
escortman
Postby postfach » Sun Dec 21, 2008 3:03 pm
Assuming you've got the idle screw on the throttle body adjusted correctly, in my experience, its either a vac leak or the idle control valve (at the back of the plenum) is rooted. Try blocking the big hose that the air goes through on that. If that solves it, get a new one, or blank it off with an aluminium plate and join the 2 water hoses together (by replacing them with 1 long hose)
postfach
Postby Emperor » Sun Dec 21, 2008 5:17 pm
Sorry to jack, but how are Altezza Traction Control setup?
Emperor
Postby escortman » Sun Dec 21, 2008 9:11 pm
found something i overlooked completly old non turbo 1j was map sensor his new is afm so the original engine loom wont be right for ecu, but cant use the turbo loom as parts as someone had chopped bits out so now need to search for 1j wiring diagrams and and ecu pinout
escortman
Postby postfach » Sun Dec 21, 2008 9:51 pm
Whats the 1J out of? I have some wiring diagrams and pinouts that might be of use to you.
postfach
Postby escortman » Sun Dec 21, 2008 9:53 pm
he said we need them for the factory non turbo 1jzge vvt afm its jzx100 chaser
escortman
Postby postfach » Sun Dec 21, 2008 9:57 pm
see if this is relevant:
http://monsterezza.blogspot.com/2007/10 ... agram.html
Should be pretty close/right, check the main things like power and earths, and check colours.
postfach
Postby escortman » Sun Dec 21, 2008 10:04 pm
dont suppose u have anything on 1jz non turbo map sensored, we're going to try wire in the turbo bits that are missing into the non turbo loom
escortman
Postby mr30%jr » Sun Dec 21, 2008 10:11 pm
Emperor wrote:Sorry to jack, but how are Altezza Traction Control setup?
50% drive by wire.
mr30%jr
Postby postfach » Sun Dec 21, 2008 10:20 pm
What's actually missing from the turbo loom? If you've got the ECU plugs and plugs that fit your sensors, the rest should be pretty easy, just match the pins on the ecu plug to their respective sensors. I've just had to make big parts of a loom to make a 1JZ-GTE work in my Z20. Go to jaycar and buy lots of heatshrink, electrical tape and split loom wrap and mix and match till you've got something that works. I bought one of those $50 dymo label makers from woolworths to help me remember what does what.
postfach
Postby the fallen303 » Mon Dec 22, 2008 8:32 am
which 1jz's came afm? :? my jza70 1jzgte is map, jzz30 soarers are map, and mates 1jzge jzx100 is also map. haven't seen an afm one before. only jz's i've seen that are afm are U.S. mk4 supras...
true house of JZ
Stay true to the origin
the fallen303
Postby Mr.Phreak » Mon Dec 22, 2008 9:44 am
VVTi's are afm aren't they??
Mr.Phreak
Postby postfach » Mon Dec 22, 2008 9:44 am
he means the 1JZ-GE is afm
postfach
Postby the fallen303 » Mon Dec 22, 2008 11:31 am
the 1jz-ge's i've seen are map. the jzx100 one is the vvti version as well.
true house of JZ
the fallen303
