kim0663 wrote:i use to use 5w50 mobil 1 on the sw20, (which was a weekend car)
It runs SOOOO nice for the first 3000kms, after that, it's not that nice so i thought i'd change this time too. and at $80 odd + toyota filter, $100 each 4500kms isn't so cheap as it's a daily driver now.
Anyone has experience with those castrol edge 5w30? $65 odd dollars, thinner too so might rev better
BZG|Bling wrote:Why fix whats not broken?
Boosted_162 wrote:I have ended up changing to Pennzoil 10w40 in all my cars (2x3SGTE/2JZGE)
engine probably isn't going to get hot enough to bring it down to that viscosity
kim0663 wrote:Mineral based oils, need the heat for them to get to that certain viscosity but from what i understand, fully-syn stuff is more stable thus if i selected a 5w30, it should be running that viscosity as long as it's not super cold?
Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
I use 10W60 with my GT4, it has got ~135k now, I change religiously every 5000kms, and use only Toyota genuine oil filter (if you get bored and open one up vs repco/ryco you will see the difference, also Toyota filter has a better seal which is pre-lubricated and mounted in such way that it is impossible for it to separate while handling).
