high comprestion pistions + boost? (2tgeu)
Postby 79rolla » Wed Jan 14, 2009 8:22 pm
hey still doing my converstion, just wondering how much boost could a low comprestion 2tgeu handi reliabilyl? there pritty strong arnt they?
just asing coz im thinking of turboing my motor, its freshly rebult late verstion 2tgeu, so thinking of turboing it mostly for cert reasons, so i could play round with 3t internails later down the line if i want...
is it worth it or not?
past: AE82 FXGT
79rolla
Postby 79rolla » Fri Jan 16, 2009 10:26 am
bump?
past: AE82 FXGT
79rolla
Postby bbq1988 » Fri Jan 16, 2009 11:00 am
just do it, who cares if it 'splodes
bbq1988
Postby IH8TEC » Fri Jan 16, 2009 11:59 am
it's all in the tune, mine is currently at 9.1:1
Postby Burning Angel » Fri Jan 16, 2009 7:14 pm
IH8TEC wrote:it's all in the tune, mine is currently at 9.1:1
i agree. tuning is the key.
i saw a rb25de+t make 290kw at the wheels on 10psi last night, theyre 10:1.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby 79rolla » Sat Jan 17, 2009 12:09 pm
accoring to a websit, the high comp pistons from factory were 9.8:1 compression ratio
will i ned to look at bigger injectors or anything for this sort of compresstion? (i dont know alot about turbo tuning) but another fourim was saying you can run 9:1 with about 6psi on pump gass, but once it gets up to bout 10:1 it needs to be run on race gas?? or would 95/98 be fine?
past: AE82 FXGT
79rolla
Postby Logan » Sat Jan 17, 2009 4:39 pm
just put some 440cc injectors from 7mgte/3tgte/nissan sr or ca i think fit.
Should be sweet for 10psi or so with a good tune.
SR Sold. Onto Other Things
Logan
Postby 79rolla » Sat Jan 17, 2009 4:56 pm
you sed ca injectors??
would ca18de injectors be big enough? or would i need ca18de injectors??
because i just so happen to have a ca18de sitting in the shed :wink:
past: AE82 FXGT
79rolla
Postby 79rolla » Sat Jan 17, 2009 5:48 pm
crap just cheaked and no injectors in it..
but still it wouldint matter if its out of turbo or na motor would it? or are they diferent from factory??
past: AE82 FXGT
79rolla
Postby touge rolla » Sat Jan 17, 2009 5:50 pm
79rolla wrote:crap just cheaked and no injectors in it..
CA18DET injectors are different from CA18DE
touge rolla
Postby 79rolla » Sat Jan 17, 2009 6:24 pm
on further investigation scrap my statment abut compretion ratio
its alot more likely to only be 9:1, do i need to wary about bigger injectors? or not warry about it?
i had wrong genoration, (mine has doble vaulve springs and a plastic oil cap lol)
http://www.geocities.com/Colosseum/4883/2tg-info.html
past: AE82 FXGT
79rolla
Postby Logan » Sun Jan 18, 2009 7:50 pm
i have nissan ones, cant remember what they are out of, but were cheap and flowed 440cc, must have been from a turbo something i guess. They do need bigger orings to fit, but they are cents from the local seals place, and i always replace all the seals when i change injectors anyway.
Logan
Postby molex » Sun Jan 18, 2009 7:55 pm
More power = more fuel
Turbo motor = more fuel
More powerful turbo motor = lots more fuel
more fuel = bigger injectors
:D
Seriously though, you'll need some good aftermarket management and some appropriately sized injectors - 440cc are relatively common and are inexpensive/flow more than enough. CA18DET injectors are likely to be significantly larger than the NA versions, likewise with just about any other na vs turbo motor comparisons.
molex
Postby 79rolla » Mon Jan 19, 2009 10:38 am
iv sused out sum sr20det injectors witch are 440cc i think.
cannot afford aftermarket engin managment yet, but have 18rgeu ecu witch runs afm and o2 sensor so shuldint have problems leaning out? can you tune the standard ecu? or shuld i look into getting aftermarket as soon as i can?
past: AE82 FXGT
79rolla
Postby fuel » Mon Jan 19, 2009 3:46 pm
how is the rebuild going anyway? got pics?
I'm pretty sure it was an 8.4:1 engine, it's the late model EFI which doesn't have hemi shaped combustion chamber and piston tops - it's the one which has an offset dome on the pistons (assuming you're still using the original pistons).
LOUD NOISES!!!
fuel
Postby 79rolla » Mon Jan 19, 2009 5:05 pm
its bult, been sitting for a bit over a yeair now
have mounts made just need small adjustments
just trying to sort out all the parts for the efi and turbo so i can start on that soon
pics as of when i first got it
and when i was making up the mounts
have pics of mounts aswell that are on my project page, just click on the picture in my sig
dont have any pics of the buld as i did that in a workshop in town,
past: AE82 FXGT
79rolla
Postby fuel » Mon Jan 19, 2009 5:47 pm
did you have any trouble finding rings, gasket sets, bearings etc? I see it has a pretty new chain tensioner too, better than the snapped one haha
LOUD NOISES!!!
fuel
Postby 79rolla » Mon Jan 19, 2009 6:14 pm
haha yeah brand new tentioner, no problem getting parts, except the oiler holes were in the wrong place on the berrings, took them back and he just field them out haha(wernt out by much) its all standard internails still, bigist problem i had with parts was they cost a grand (including seailss and a cupple of hrs prep work by them, god thing i did most of it myself then bult it myself, oh yeah the top cam chain they got was too long so they cut it dow for me and also got them to set up cam timing aswell coz i didint know what to do with it lol (just the upper chain)
he commented on the condition of everything being in relly good order too and all dimentions were standard too!
past: AE82 FXGT
79rolla
Postby 79rolla » Tue Jan 20, 2009 9:10 pm
one last question, how do i re map the ecu? can it be done? di i have to take it to a tuner??
its got an 18rgeu ecu and afm if that makes any diferance.
cheres, help so far has been verry... helpful...( :lol: )
past: AE82 FXGT
79rolla
