AE86 LSD/Diff options????
Postby AE86fan » Sat Jan 17, 2009 4:28 pm
Just pulled my diff out and found the factory LSD (prefacelift) is lunched, which would explain why Im not getting any traction.
I just cant afford to buy a new 86 aftermarket LSD (TRD, cusco, kaaz etc), if I could find one, and am not too keen on getting a second hand one if its going to need money spent rebuilding etc.
The car is making 180 hp atw (turbo), so I dont need anything too industrial and am keen to try and keep the weight down.
The car is primarly used for track days and Im aiming for a set up that can be driftable as well.
Keen on any help and ideas on what diff or lsd could be made to fit without too much expense....cheers.
1984 NZ AE86
AE86fan
Postby jakesae101 » Sat Jan 17, 2009 9:07 pm
shortened hilux diff factory lsd some of them and heeps of ratio options just have to modify the mounts
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby rollaholic » Sat Jan 17, 2009 9:16 pm
the hiluxes never got proper LSDs tho
F series is better choice imo, and allows you the option of getting good aftermarket stuff later as altezzas use an F housing also
Postby d1 mule » Sun Jan 18, 2009 2:29 am
if mainly trackdays, just find a open T series head and lock it..... easy.
iv got a E (7.1") series in my ae70 and its had 2 track days and its all good
but as rollaholic said, if thinking of upgrading do a F seried before a G (hilux)
d1 mule
Postby rollaholic » Sun Jan 18, 2009 8:36 am
i dont know how useful a locker would be at grip days though :P
Postby d1 mule » Sun Jan 18, 2009 12:01 pm
im fairly sure the V8 supercars run ford 9" minispools, sp basically a locker under load
d1 mule
Postby Logan » Sun Jan 18, 2009 7:47 pm
not alot of time difference lap wise between welded job ,which had for a very long time, and a good trd LSD, but the trd LSD does make the car slightly easier to drive, and can get better turn in. Id go welded for a " " grip " " car with out second thought for value for money.
SR Sold. Onto Other Things
Logan
Postby AE86fan » Sun Jan 18, 2009 8:11 pm
Sweet, I might see what I can find in a F-series.....are all f-series diffs 5x100?? anything 4x114.3??
1984 NZ AE86
AE86fan
Postby gepsk8 » Mon Jan 19, 2009 2:29 pm
no u can get both of them 100x5 normal comes out on the diesel townace/liteace
O272754663
gepsk8
Postby Logan » Mon Jan 19, 2009 4:20 pm
crown= 5x114,3 live axle 5 link disc brake,
Logan
Postby FULLOC » Tue Jan 20, 2009 5:49 pm
ive got a locked mx73 f series and its mint. wouldnt go hilux from what ive heard its too heavy and torsen lsds are no good for the drift although sweet for grip and cheap as far as lsds go(altezza factory lsd into f series housing+shims <$500)
also i just scored an f series (open) out of a 3t carina for $20 so cheap as :)
FULLOC
Postby matt dunn » Tue Jan 20, 2009 7:13 pm
rollaholic wrote:i dont know how useful a locker would be at grip days though :P
I run a welded diff, and would do so over a LSD anyday,
the plate type are no good as they wear and loose tension and are no good for decent power,
and have had trouble with torsens casuing issues at speed in some cars
Postby mr30%jr » Tue Jan 20, 2009 9:24 pm
for road/track day.
TRD or kazz all the way. will never break again. not sure how long lockers last and prolly reallllllly harsh on your rubber and other components
mr30%jr
