gen 2 3sgte into st165 (gen 1 3sgte) celica ???
Postby Mr_procrastination » Thu Jan 22, 2009 12:45 pm
Ok so really wanting to know the external differences between the 1st and 2nd gen 3sgte engines, and what bolt up problems i will run into?
I have a complete st165 with smokey engine and a ready to be runin gen2 3sgte longblock that has been waiting for far to long to be put in a car...
So naturaly i see a good opertunity :)
Thanks
Mr_procrastination
Postby mr30%jr » Thu Jan 22, 2009 12:51 pm
if your ploping the gen1 head on the gen2 its a rather simple swap.
you will however run into interesting bits when it comes to the oil adaptor and heat exhchanger id have to go investigate theres a little heat exhanger on the block mounted with 2 big bangos you will see it there and i dont think the oil system works quite the same way.
mr30%jr
Postby CelicaGT8 » Thu Jan 22, 2009 10:22 pm
If your just changing the head there wont be any problems, Nothing will really change except the mountings on the head for the intercooler.
I have a 165 block with a 185 head and its sweet, the only thing you will have a problem with is if you put a 185 turbo on a 165 block as the turbo sits really close to the oil lines to the cooler.
CelicaGT8
Postby CelicaGT8 » Thu Jan 22, 2009 10:26 pm
But if your just putting the 185 engine into a 165 i have done this also, apart from the wireing its more or less the same, youd want to run the 165 intercooler so you dont have to cut a hole in your bonnet. but it wont bolt up to the head, but you can figer something out.
no real problems in the swap.
CelicaGT8
Postby Mr_procrastination » Tue Jan 27, 2009 11:13 am
ok cool.
Was thinking of bolting the all the st165 engine accesorys onto the st185 engine and putting that in as only have the bear engine :) will that be pretty straight forward do you think ?
Mr_procrastination
