3sgte from gtt caldina , incressing boost from factory 10psi
Postby toycustoms » Fri Jan 23, 2009 2:37 pm
hey shaun here again
i have put a bleed boost tap between the turbo and actuator and can only get it to run 12 psi boost, factory for it i think is 10 psi.
does the computer not allow any further boost ingress?
if i wined the tap any further it will run factory 10 psi like usual
i can see another pipe from the actuator that leads to a censor and then goes back to the intake manifold, does this switch over wen it detects the actuator not opening as far as it should be thus switching it back to a factory psi of boost?
any answers would be wicked
cheers shaun
toycustoms
Postby Santa'sBoostinSleigh » Fri Jan 23, 2009 3:13 pm
do a search, its been covered a million times before
1) factory boost is more than 10PSI
2) putting a boost tap on a caldina is a stupid idea, unless you like your motor blowing up
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby 99gtt » Fri Jan 23, 2009 7:02 pm
you need to block off the vsv first other wise you cant adjust the boost .Boost cut is at 23 psi
SOON TO BE 500 HP
99gtt
Postby slighty_looney » Sun Jan 25, 2009 6:43 pm
Santa'sBoostinSleigh wrote:do a search, its been covered a million times before
totally not a stupid idea! my mates gota 3sgte caldina endine in his ke30, makes 235kw at the wheels on 19psi :P sucess on the stock engine!
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby flygt4 » Sun Jan 25, 2009 6:53 pm
the engine itself isn't the problem, its the combination tune/ecu and engine.
whats the bet its not a standard GTT ECU running the KE30? and if it is its obviously been tuned to get the dyno figure.
point is there are other things to consider when increasing the boost on a GTT, not just "crank it up au!"
i actually think this question or some form of it gets asked at least every fortnight.
flygt4
Postby escortman » Sun Jan 25, 2009 7:11 pm
yeh mate bumped his up 2 20psi went like a fukin cut cat for just over a month
4x4 toyota blizzard offroader
escortman
Postby iOnic » Sun Jan 25, 2009 7:42 pm
caldinas aren't quite "put a tap on it and crank it up" cars.....they're a little delicate in that respect :lol:
someone with a lot of knowledge on these cars needs to make an FAQ about them i think :lol: will save the amount of topics popping up on a weekly basis asking this sort of question
Postby flygt4 » Sun Jan 25, 2009 8:50 pm
iOnic wrote:caldinas aren't quite "put a tap on it and crank it up" cars.....they're a little delicate in that respect :lol:
nobody bothers to look anyway, we will still get the same question every 2 days. sometimes i wonder why we have a search function
flygt4
Postby 99gtt » Mon Jan 26, 2009 12:49 am
So what if the same question pops up instead of writing a negative response awnswer the poor mans question . Or just ignore the post you guys a way too uptight :)
SOON TO BE 500 HP
99gtt
Postby 99gtt » Mon Jan 26, 2009 12:57 am
Mine makes the same power on factory ecu used to run 20 psi on old factory turbo run 14 psi now with t04 still factory ecu had the car for 7 years still going strong. People need to stop going on the minority of people who have blown there engines , which could be from poor maintnance, crap fuel should be 98 octane.
SOON TO BE 500 HP
99gtt
Postby 2jayzgte » Mon Jan 26, 2009 7:35 am
I would splash some money and get a dual solenoid boost controller something along the lines of a Apexi AVC-R or a Blitz SBC I-D both really good boost controllers and will give you optimal control of what boost you want to run.
2jayzgte
