by crispy'86 » Thu Jan 29, 2009 6:55 am
I'd be a bit careful on this one. Sounds like it could possibly be cvjoint noise but those bzr boxes do give up the ghost when they get a hard life.
Does it only click just on turning corners? or does it click when you accelerate quckly in a straight line? Just seems a bit coincidental it makes that noise when turning after you did a launch. best indication is to drain the oil and inspect it very carefully. If it's got silver streaks in it or majorly silver coloured oil then you've definitely got internal issues with the gearbox. Does it just make the sound on right lock only or both left and right?First thing to do would be find a quiet street OR a large carpark, turn hard lock left and right while applying the brake and accelerating, you must accelerate enough so the engine doesn't stall. go from one lock to other. If it's just on right lock and goes away when you straighten the wheel then chances are your left outer cv joint is had it. I'd try this method first to eliminate cv noise.There'd be nothing worse than changing gearbox oil and find you've still got the same noise, but you did say it's hard to change into 2nd.
So do cv test first, check for split cv boots when you jack it up and put axle stands under it.
