BZR gear oil
BZR gear oil
Postby kim0663 » Thu Jan 29, 2009 12:37 am
which gear oil runs best on a BZR? 6spd
Does toyota have genuine oils for it? or do they suggest atf dex3 like most of them.
Mr2 GT-S
330ci M
kim0663
Postby AceSniper » Thu Jan 29, 2009 1:40 pm
castrol VMX or redline
AceSniper
Postby sergei » Thu Jan 29, 2009 2:56 pm
don't run ATF. I would recomend syntrax or multitrax, it has to be GL5 due to torsen.
Postby kim0663 » Fri Jan 30, 2009 1:37 am
mm didn't read your post fast enough and just went out and grabbed some MT90,
Worked a treat, lsd seems to grab much more predictable too
Thanks alot anyway!
Mr2 GT-S
330ci M
kim0663
Postby Stott69 » Sun Feb 01, 2009 10:08 pm
out of intrest how much was that and where from?
Image jzs147 Aristo money pit
Stott69
Postby sergei » Sun Feb 01, 2009 11:07 pm
kim0663 wrote:mm didn't read your post fast enough and just went out and grabbed some MT90,
Thanks alot anyway!
The factory LSD shouldn't be felt. What I mean is that torsen LSD works seamlessly (no kicks or "grabbs"). Unless you have aftermarket LSD that is....
Postby kim0663 » Sun Feb 01, 2009 11:49 pm
Thanks alot anyway!
yeah i know what you mean, but it actually feels like a limited slip diff now flooring it on corners, before it use to feel more like a locked one :wink:
Mr2 GT-S
330ci M
kim0663
Postby mr30%jr » Mon Feb 02, 2009 9:33 am
LOL torsen lsds arnt effected by the oils used... its just a bunch of gears. think your getting confused with a viscous
mr30%jr
Postby Py7h0n » Mon Feb 02, 2009 5:05 pm
Torsens are very affected by the oil you run in them. Mostly to do with sheer and weight but thats another discussion.
The Redline Shockproof series is absolutly awesome with a torsen - Yes you will notice it. Kinda like putting normal oil in a LSD :).
Py7h0n
