Crox tools - Flairing intercooler pipeing
Postby CelicaGT8 » Sun Feb 01, 2009 9:46 pm
Greetings all.
I need my inter cooler pipeing flaired with a crox tool, i took it to tube bending ltd and they could only do my straights - which they made a total mess of, but they couldnt do my bendy bits.
anyone no of a good place to send them?
Thanks,
Big Rob
CelicaGT8
Postby strx7 » Sun Feb 01, 2009 10:06 pm
buy a cheapish set of vicegrips, weld up them jaws on them to be the right shape to do it yourself. A tad on the 'rangi' side but it does the job and it you take your time doing it you'll get a VERY even finish.
Postby Lloyd » Sun Feb 01, 2009 10:25 pm
Or run a bead of weld around a cm or so down from the end. Works wonders
Postby CelicaGT8 » Sun Feb 01, 2009 10:35 pm
Thats a good idea with the vice grips,,, think ill give it a try...
Thanks
CelicaGT8
Postby 85AW20v » Sun Feb 01, 2009 10:38 pm
A crox tool is designed for soft metals like copper so would probably work on aluminium if that's what your intercooler pipes are made from. Any plumbing workshop should have a bench tool that would do the job. I've only seen formers - which fit into the pipe you're croxing - for copper up to 2" but if the operator knows what he's doing would be able to do any size pipe.
See ya
Simon
85 MR2 20v
85AW20v
Postby strx7 » Mon Feb 02, 2009 1:03 pm
HRT wrote:Or run a bead of weld around a cm or so down from the end. Works wonders
Especially if you've got one that keeps blowing off
