Spring rates
Spring rates
Postby 1I1 » Wed Feb 04, 2009 12:44 pm
Ok Corolla went in for cert on coilovers and superstrut calipers yesterday. When the car was dropped back at work i was told it failed - the springs are too hard. He suggested softening the shocks right up to see if that helps. Took it back at lunch time for a recheck but got told it was borderline (a pass tho :D ). My question is what spring rates do people run? The BC's i got came with 6kg/4kg front/rear and the kit was meant to be the "street version".
(car is AE111 sedan with full interior etc)
TRD Clicky >>Here
1I1
Postby Distrb » Wed Feb 04, 2009 12:47 pm
i run 5 kg/mm front and 3.5 kg/mm rear in an AE82 Fx-Gt on the street. Shocks are reasonably stiff valving also.
Distrb
Regular Poster
Postby neo » Wed Feb 04, 2009 12:59 pm
My Bazda Suspension.
Racecar with 15" wheels - got its cert with
1 x race set (adj. damp.) + 8kg front - 6kg rear springs
When I tried the following in my roadcar with 17" wheels, I removed it immediatly as it was stupidly bad.
1x road set + 6kg front - 4kg rear springs
neo
Postby 1I1 » Wed Feb 04, 2009 1:08 pm
Yeah corolla has 17's and 205/40 tyres. hmm when sam (NILPSI) came for a ride two weeks ago he thought the ride wasn't too bad
TRD Clicky >>Here
1I1
Postby pc » Wed Feb 04, 2009 6:58 pm
8kg front and 6kg rear in my AE82... not really a "road" car, as it's not comfy driving on the road anymore.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Dell'Orto » Wed Feb 04, 2009 7:01 pm
Danny did your cert eh?
Postby d1 mule » Wed Feb 04, 2009 7:06 pm
got my old Z10 soarer certed with 8 and 6kg adjustables no problem
d1 mule
Postby xsspeed » Wed Feb 04, 2009 7:10 pm
neo wrote:When I tried the following in my roadcar with 17" wheels, I removed it immediatly as it was stupidly bad.
6F and 4R was bad? Was that a Bazda set as well?
Postby Dell'Orto » Wed Feb 04, 2009 10:47 pm
d1 mule wrote:got my old Z10 soarer certed with 8 and 6kg adjustables no problem
Z10 is probably a wee bit heavier than a AE111 Corolla, or enough at least to make a difference.
Postby rollaholic » Wed Feb 04, 2009 11:35 pm
got 8kg fronts and 6kg rears in my trueno.
not the greatest ride on our bumpy streets :(
Postby 1I1 » Thu Feb 05, 2009 8:00 am
Dell'Orto wrote:Danny did your cert eh?
Yup. Getting it's plate today :D yay legal.
Yeah i don't mind the ride of these springs but i don't want the problem of spot welds failing etc.
Been told by contact at redline to check pre-load set up so that will be something for the long weekend
TRD Clicky >>Here
1I1
Postby Bazda » Thu Feb 05, 2009 2:03 pm
Yes
depends what ur definition of bad is.
I dont think its the spring rate, its more the shock rate.
When I run 14kg springs from 8kg I dont really notice that much difference on the road.
If you want a nice ride stick with standard shocks and lowering springs :).
If u want adjustables that are soft, the car wont handle very well.
Postby FLAWLES » Thu Feb 05, 2009 2:11 pm
i run with bc coil overs in my jzx100
my rates are 12kg on the front
10kgs on the back
backs are still a bit to soft, mostly to do with the dampning rate tho
last three digits on the spring part number are the rates
FLAWLES
Postby pc » Thu Feb 05, 2009 6:06 pm
Bad for comfy cushioned road driving, really good for fast track/sealed sprint driving.
You can't have both.
red car
Manfield - 1:24s
pc
