RedMist wrote:What ECU is it running?
Rob wrote:Could be the air flow meter
mr30%jr wrote:they do run but if the fuel pump switch is facked too they wont
you pretty much cant rev them
lucasthefallen wrote:soarers also have a fuel controll computer ( located in passenger rear quarter window trim ), they are common to shite themselves.
cat007 wrote:1hypo3 wrote:have you checked for DTCs
DTC?
lucasthefallen wrote:cat007 wrote:1hypo3 wrote:have you checked for DTCs
DTC?
diagnositc trouble code.
cat007 wrote:When jumping 12volts to the fuel pump, it runs, but like a pile of sh*t and flooring it, it pings and coughs and sounds like its running on 4 cylinders.
Mr.Phreak wrote:Depending on how much was butchered fitting it, it could be anythingcat007 wrote:When jumping 12volts to the fuel pump, it runs, but like a pile of sh*t and flooring it, it pings and coughs and sounds like its running on 4 cylinders.
Sure it isn't running on 4?? Quite common for coils and ignitors to die
