Lexus V8 in surf died....
Postby cat007 » Sat Feb 07, 2009 1:21 pm
Hey all,
A mate of mine has a Lexus V8 in a surf. Bought it that way. He's really onto it (being a marine engineer type), but is baffled by electricity.
Basically - his partner said there were a few small "pops" and then it died.
When jumping 12volts to the fuel pump, it runs, but like a pile of sh*t and flooring it, it pings and coughs and sounds like its running on 4 cylinders.
Do these engines (early model we think) run a fuel pump resistor?
Also when the surf was going - it was gutless as hell. Not sure if that means anything?
Postby thegreatestben » Sat Feb 07, 2009 4:39 pm
originally engine would've had a seperate ecu.
thegreatestben
Postby RedMist » Sat Feb 07, 2009 5:09 pm
What ECU is it running?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Rob » Sat Feb 07, 2009 7:02 pm
Could be the air flow meter
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby cat007 » Sat Feb 07, 2009 8:23 pm
RedMist wrote:What ECU is it running?
Just standard I assume - Soarer we think.....
Postby cat007 » Sat Feb 07, 2009 8:24 pm
Rob wrote:Could be the air flow meter
Really? The fuel pump doesnt turn on though - and when he 12 volts it, the engine runs, but runs like a sack of *something*......
Postby cat007 » Sat Feb 07, 2009 8:30 pm
He has swapped AFM to try and eliminate the issue of it running purely, i.e. low power etc but hasn't swapped the AFM since the complete failure....
Postby ee904age » Sat Feb 07, 2009 8:33 pm
Greed. IIRC the AFM controls the fuel pump to a certain degree, When the AFM reads no airflow it cuts the fuel?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby rollaholic » Sat Feb 07, 2009 8:43 pm
in my experience toyotas run if the AFM is bung, just not well
Postby mr30%jr » Sat Feb 07, 2009 9:05 pm
they do run but if the fuel pump switch is facked too they wont
you pretty much cant rev them
mr30%jr
Postby cat007 » Sat Feb 07, 2009 9:26 pm
mr30%jr wrote:they do run but if the fuel pump switch is facked too they wont
It revs ok - just sounds like a sack......
Sounds like its a "big gay 4 cylinder" - smooth still - but not quite a V8.....
Postby FXGTV » Sat Feb 07, 2009 10:41 pm
Yup, sounds like AFM.
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby lucasthefallen » Sat Feb 07, 2009 10:50 pm
soarers also have a fuel controll computer ( located in passenger rear quarter window trim ), they are common to shite themselves.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby cat007 » Sat Feb 07, 2009 10:58 pm
lucasthefallen wrote:soarers also have a fuel controll computer ( located in passenger rear quarter window trim ), they are common to shite themselves.
Ah - well there's a "computer" type unit, about the same size as a window controller unit etc, that they previous owner has written "fuel pump" on. I'm guessing it's something to do with that. Will test tomorrow....
Thanks all.....
Is there anyone in the north shore area who knows these engines at all? The car's on the north shore (albany area) - would really appreciate it if someone could come take a nosey. tomorrow (Sunday)......
Postby 1hypo3 » Mon Feb 09, 2009 12:37 pm
have you checked for DTCs
1hypo3
Postby cat007 » Mon Feb 09, 2009 1:19 pm
1hypo3 wrote:have you checked for DTCs
DTC?
Postby lucasthefallen » Mon Feb 09, 2009 4:11 pm
DTC?
diagnositc trouble code.
lucasthefallen
Postby cat007 » Mon Feb 09, 2009 4:17 pm
DTC?
Do they have that? Where the Engine Check Light will flash giving the code? hmmmm if so - I'm not even sure the guy that installed the engine hooked up the engine check light. I'll ask tonight.....
If he hasn't - is it hard to hook one up in the mean time? Or is there any other way of doing the code test?
Re: Lexus V8 in surf died....
Postby Mr.Phreak » Mon Feb 09, 2009 7:31 pm
Depending on how much was butchered fitting it, it could be anything
cat007 wrote:When jumping 12volts to the fuel pump, it runs, but like a pile of sh*t and flooring it, it pings and coughs and sounds like its running on 4 cylinders.
Sure it isn't running on 4?? Quite common for coils and ignitors to die
Mr.Phreak
Postby cat007 » Mon Feb 09, 2009 7:32 pm
Mr.Phreak wrote:Depending on how much was butchered fitting it, it could be anything
It IS running on 4 - well sounds like it - but the fuel pump doesnt turn on unless you hardwire it.....
