***4agze turbo starlet boost problem!!!***
Postby evil_si » Thu Feb 12, 2009 4:55 pm
take the boost controller off the actuator line, and put it into the top,
personally id do as i mentioned earlier, take all boost control lines off the wastegate and go for a drive, see if you get more boost,
if you do its your boost control system
if you dont you either have a fcked turbo leaking manifold or boost leak
evil_si
Postby stefegg89 » Thu Feb 12, 2009 6:39 pm
yip the arrow is pointing towards the intercooler piping
stefegg89
Postby bluemaumau » Thu Feb 12, 2009 6:42 pm
haven t read the thread but...
tsoob wrote:they have a little arrow that goes towards the acutator
stefegg89 wrote:yip the arrow is pointing towards the intercooler piping
:lol:
Postby tsoob » Sat Feb 14, 2009 5:45 pm
bluemaumau wrote:haven t read the thread but...
:lol:
that would be a good place to start.....
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby stefegg89 » Tue Feb 17, 2009 7:00 pm
uh na the arrow is pointing to the side ov wastegate and it is t off to the intercooler piping
stefegg89
Postby TRD_ZERO » Tue Feb 17, 2009 7:12 pm
Why dont you just post a few photos? I think it will speed things up alot more with less frustration.
Previous:
TRD_ZERO
Postby stefegg89 » Thu Feb 19, 2009 6:53 pm
im not shore how to add photos whats your email adress and i will send to you is that ok?
stefegg89
Postby stefegg89 » Wed Feb 25, 2009 6:42 pm
photos will hopfully be added to mo i have just found out that my 1 stage boost controler is only brown wired to earth and the other wire isnt hookd up to the power...would that b making it not work problery
stefegg89
Postby TRD_ZERO » Wed Feb 25, 2009 7:04 pm
My friend had boost problems too when both his wires wernt hooked up properly.
Here is ur pics
Previous:
TRD_ZERO
Postby stefegg89 » Fri Feb 27, 2009 6:45 pm
so you think it could be becuase thje blue wire on the boost controler isnt wired up to the ignition
stefegg89
