knocking noise ? ae92
Postby Guss » Sat Feb 14, 2009 6:42 pm
my ae92 gt corolla has developed a knocking noise (around 4 time a sec) while cruising along at 60kph in 4th and 5th.
It began with a loud knock when accelerating hard in 1st.
CV's do not click while turning hard and if load is increased from cruise to accel it is no longer noticeable.
I think it might be there at motorway speeds too but not 100% sure.
any suggestions as to what it could be
Guss
Postby FXGTV » Sun Feb 15, 2009 7:28 pm
Check your wheel nuts. Is it a knock from the engine, or under the car? more details :)
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby Guss » Sun Feb 15, 2009 8:13 pm
noise is coming from front left (of drivers eat at least), wheel nuts are fine only really noticeable in 4th and 5th cruising at 60kph. other sppeds it's ok and accelerating from to and around 60 it goes away only at cruise is it noticeable.
cornering load has no affect.
its actually more frequent than the 4/sec i posted originally maybe 10/sec.
have an idea that it could be something in the gearbox ?
diff has been really whiny since i got it 8 months ago, fluid was changed and no real difference.
everything is stock except lowering springs.
Guss
Postby TRD_ZERO » Mon Feb 16, 2009 6:30 pm
check the hanger bearing mount is still attatched might be flopping around. those bolts keep popping off
Previous:
TRD_ZERO
Postby Adamal » Mon Feb 16, 2009 6:54 pm
Is the knocks/sec the same between 4th and 5th? That being the case, it won't be engine related.
Postby gepsk8 » Tue Feb 17, 2009 7:43 am
60kph, change down, engine speed will be to low. if its 4age then front engine propably $&#$%.
O272754663
gepsk8
