Bushings
Bushings
Postby solitaire » Tue Feb 24, 2009 4:18 pm
Hiya, did a search under "bushings" but could not find an answer
I have just received a bushing kit for the sw20, anyone have any advice for getting rid of the old rubber bushings in a resonably equiped home garage?
Some website mention burning them out but i dont have any welding gear or anything like that.
Keen to hear from anyone who has done this before :D
AE92, KZJ120, KDJ120
solitaire
Postby Bling » Tue Feb 24, 2009 5:26 pm
Normally referred to as bushes on here.
Burning is what I heard too, maybe take off you hot plates on ya bbq and suspend the bushes above the burner?
I'm assuming you have a mans kitchen anyway :lol: easily accessible hot flame 8)
Postby solitaire » Tue Feb 24, 2009 5:28 pm
BZG|Bling wrote:Normally referred to as bushes on here.
Didn't think of that... Nice one mate ill give that a crack :D
solitaire
Postby Lloyd » Tue Feb 24, 2009 5:49 pm
Which bushes exactly? There aren't any you should have to burn out
Postby Bling » Tue Feb 24, 2009 6:00 pm
solitaire wrote:Didn't think of that... Nice one mate ill give that a crack :D
Yeah came to me straight away as i'm a gas fitter :lol:
Postby soven » Tue Feb 24, 2009 6:06 pm
small butane torch?
soven
Postby MrOizo » Tue Feb 24, 2009 6:46 pm
soven wrote:small butane torch?
was going to add this too. :)
MrOizo
Toyspeed Legend
Postby Bling » Tue Feb 24, 2009 7:31 pm
I put a butane torch under "welding gear or anything like that", never know though I guess :)
Postby rwd_mayhem » Tue Feb 24, 2009 7:33 pm
Lloyd wrote:Which bushes exactly? There aren't any you should have to burn out
i agree. should be able to be pressed out. i wouldn't be heating up anything to do with suspension.
current: 1975 Valiant Regel
rwd_mayhem
Postby Mr Revhead » Tue Feb 24, 2009 8:44 pm
you can burn bushs out, but you have to burn the rubber, not heat the steel!
some bushes are press out, and some require you to keep the old shells in place and burn out the rubber. ask the supplier what you do with the brand you got
Postby rollaholic » Tue Feb 24, 2009 8:57 pm
burning that sort of stuff takes way longer than you would expect
and stops being fun after the first face full of ash / fumes
Postby ChaosAD » Tue Feb 24, 2009 9:10 pm
Just cut the end off the bush and prise it out with a screwdriver or something
ChaosAD
Postby Mr Revhead » Tue Feb 24, 2009 9:14 pm
rollaholic wrote:burning that sort of stuff takes way longer than you would expect
yeah...... very true
Postby solitaire » Tue Feb 24, 2009 9:25 pm
Whoa... you change your name? Your freaking me out brother :lol:
these are the bushes: http://www.twosrus.com/catalog/product_info.php?cPath=22_61&products_id=431
Front and rear control arm bushings
Front and rear strut bar bushings.
Front and rear anti-sway bar bushings
Rear strut bar control arm to chassis bushings
Dont have any butane torches or anything like that im afraid... could cut the end off i guess... heating the metal is a no no?
solitaire
Postby Mr Revhead » Tue Feb 24, 2009 10:00 pm
hmm iv only done an aw11 but im pretty sure they use a lot of the same bushes, and they were press out.
however you can burn the rubber out and carefully hacksaw the shell so you can collapse it and remove if you cant get to a press
Postby solitaire » Tue Feb 24, 2009 10:25 pm
Mr Revhead wrote:hmm iv only done an aw11 but im pretty sure they use a lot of the same bushes, and they were press out.
Oh right... what sort of people have a press?
solitaire
Postby Bling » Tue Feb 24, 2009 10:38 pm
Engineering places, some mechanics i'm guessing.
Sometimes you can press the new ones in using a vice with a bit of lube. Possibly even press the old ones out with a vice too. Would just take a bit of creativity :lol:
Postby Lloyd » Tue Feb 24, 2009 11:04 pm
A hammer, a screwdriver and an air powered hacksaw should get any out
Postby Malcolm » Tue Feb 24, 2009 11:16 pm
I just did the ones on my mr2 using a bench vice and a number of sockets etc to act as supports/drifts.
Postby solitaire » Wed Feb 25, 2009 7:41 am
Some great ideas here, thanks everyone :D
solitaire
