soopachargen wrote:you really should have some sort of protection on the cable, a kill switch is just a manual switch, you need a circuit breaker or fuse if you wanna do it safely.
and i hope he sells it with more mounting hardware than that strap, you really need to bolt the battery down to something solid.
RomanV wrote:
Cant think of anything worse than having a car burn out on account of a wire that rubbed through and grounded out on the chassis.
soopachargen wrote:the fuse is to protect the wire if it arcs out on the body of the vehicle, so you want it as close to the battery as possible.
and if you have an unsealed battery you have to have it in a box, it doesnt matter how it is held down.
