matt dunn wrote:But best thing to do is pull the head off.
Quint wrote:^^ PM sent.
To save from creating a new thread.
Differances between the 1G-GE and the GTE? Same cams? Shims? and cambelt? Or are they all differant?
Having trouble locating parts for the GTE is all while GE parts are plentiful.
Quint wrote:, turned out that the cam lobe had worn oddly on cylinder 2 IN side causing the shim to become dished, the shim eventually 'jumped' off the bucket causing the very loud noise.
MAGN1T wrote:Quint wrote:, turned out that the cam lobe had worn oddly on cylinder 2 IN side causing the shim to become dished, the shim eventually 'jumped' off the bucket causing the very loud noise.
Your explaination doesn't make sense to me.
All the Toyotas I've seen, the shim sits on top of the valve stem, the bucket sits on top of that, the cam runs on the bucket..... so how can the shim come out? the valve might be bent?
Of course you' d have already given it a compression test to make sure it's OK and check there's no oil on the thread of the plug?
Maybe I'm on completely the wrong track?
Steve
Steve
mjrstar wrote:rumor has it N/A cams are worth around 30hp with the correct supporting mods. I'm running them in mine and it seems to work ok.
i may post up some of the oil system mods i have done to my spare engine at some stage (if anyone is interested)
mjrstar wrote:anyone keen on an adjustable cam gear group buy?
They're in your build project thread aren't they?
sergei wrote:MAGN1T wrote:Quint wrote:, turned out that the cam lobe had worn oddly on cylinder 2 IN side causing the shim to become dished, the shim eventually 'jumped' off the bucket causing the very loud noise.
Steve
Yes you are, most toyotas have shims on top.
Very rare for them to have under, only higher performance toyotas have under.
mjrstar wrote:[
yep, pretty sure TRD or someone do shim under followers for the likes of high rpm 4age's.
the retaining lip is pretty shallow, imagine how nasty it would be with reground cams and thicker shims...
