Dazed&Confused wrote:They made a 4wd corona?
iOnic wrote:ST195's are 4wd
There were a couple of things but not majors. The fuel links onto the fuel rail are different, but if his GTE engine came with the bits of fuel lines he should be able to mix and match the two without having to buy anything. The plumbing for the heater unit that goes through the firewall is different, (on the GTE it exits out the back where the thermo is), I found that a rav 4 pipe works good if one end is cut off - the FE pipe has too much of a kink in it.
