o0hoe rolla0o wrote:i have a sr20det Gbox and flywheel i could been inticed to sell at the right price i wouldnt be after to much just a fair price
Adamal wrote:The Autech motor isn't bad, but its by no means stellar.
Its actually one of the older low intake port models without VCT. Its just that its more highly strung, bigger cams with more lift, higher compression etc.
In all honestly, being that they come from an Autech car, they'd be more expensive than a SR20VE
Adamal wrote:Oh yea. I got a lil mixed up there![]()
They're a good engine then. Rated to about 200NHP (Nissan HP). Or about 230THP (Toyota HP)
Truenotch wrote:They go fine, providing you can find a FWD SR20det. Front, rear and 4wd ones are all cast differently.
Easiest way could be to take the sr20de and add a Turbo to it.
Twolitre wrote:Truenotch wrote:They go fine, providing you can find a FWD SR20det. Front, rear and 4wd ones are all cast differently.
I didn't think there was such a thing as a fwd sr20det factory powered Nissan.
Seems quite common in aus to convert SSS Pulsar's to turbo using U12/U13 Bluebird or even Gti-R engines, and apparently the 4wd SR20DET's bolt straight up to the fwd gearboxes making for a simple conversion.
Only asking as I might be going to aus so looking for something with some decent bang for buck such as this one
Truenotch wrote:They are definitely all different, remember 4wd ones being hot property when I was working for the nissan wrecker here. It would be easier to convert the 4wd one than it would be to try and make a rwd one fit. Whatever you do, don't get a GTiR engine! It's impossible to get any parts for them, and they are completely different to everything else that nissan built.
slammed_integral wrote:coming out of left field over here, and also unsure weather has been suggested or not yet, but fit a rotary to it
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
Users browsing this forum: No registered users and 26 guests
