Lloyd wrote:Out of curiosity, why not go the 1UZ option? No reason to keep the injection if you don't want to, not too hard to get box and things to suit etc
any proof to back that claim up??Adoom wrote: The 302 will be a huge heavy lump of cast iron. The 1UZ is all alloy. MUCH lighter.
30kg Pffft,have seen numbers for 1UZ a smidgen under 200kg, but unsure what un-needed accessories were weighed? which is smaller and is better supported by many many years of factory and aftermarket supply?postfach wrote:Ford 302 V8 weighs 208kg, 1UZ is 177kg*
*according to the internets
Adoom wrote:I think the 302 will make the starlet handle like crap.
The 302 will be a huge heavy lump of cast iron. The 1UZ is all alloy. MUCH lighter. It is still way heavier than a 4cylinder. You may also want to mount the 1UZ behind the engine x-member, which means you have to dispose of the whole firewall and make a new one.
I have heard that the 1UZ is 'similar' dimensions to the Rover V8.
There is a V8 Starlet in the lower Nth island somewhere, I saw it once when I was at manfield. He never opened the bonnet where I could see so I dunno what kind of V8 is was. The Starlet was kermit green and extra extra wide with some HUGE slicks on it.
OOOOH Look I have a photo!
steve murch wrote:I'm going to get shot for this one but i hate to say it but a small block Chev is cheaper to mod than a 1uz,the only reason i wouldn't go with the ford is cost.
you spend 5k on a Chev and you can can have 450-500hp and there isn't a big weight difference between that and a 1uz.
you put ally vette heads on it and that takes 30kgs off again.
a new set of edelbrock performer heads or world cup heads are 1800new,with valves and springs.
hyper pistons are 500 a set,eagle rods 600 a set etc etc,due to the fact its the most commonly produced motor in the world makes for cheap parts.
if you can find a old Donovan ally block or a rodec then there's no weight difference and its a smaller motor than a 1uz.
and it'll make a ton more torque, now add a turbo? hmmm then it gets interesting
fangsport wrote:steve murch wrote:I'm going to get shot for this one but i hate to say it but a small block Chev is cheaper to mod than a 1uz,the only reason i wouldn't go with the ford is cost.
you'll get a bluey for not appeasing the the 1UZ fanboys,Steve!!
the only thing that makes the 1UZ a good option is in a class like superstocks where 4l is on the cusp of the CI/CC limit (but they should of introduced an RPM limit to keep costs down).
