sergei wrote:if thermostat is suspect then check radiator when car is hot, it should be hot as well. If you don't mind getting dirty and wet, you could pull the thermostat out and check it in boir try running the car without it to see if it still overheats).
Also maybe your water pump "lost" its impeller?
sergei wrote: you could pull the thermostat out and check it in boir try running the car without it to see if it still overheats.
