Celica RA45 wrote:if it is a gen 2 3sge you can put a drain back between no 2 and 3 on the exhaust side right where the oil flows to go past the valve springs and also just under the disy ,but make sure you dont go through into the water jacket and if the motor is going rear wheel drive it will sit 20mm off being level as they lean to the exhaust side with a 2s sump and bellhousing with w box or t50 box
1 other thing on these motors is we pull the head and put a 2mm oil restricter in the block to stop the 6mm hole of pushing up to much oil
they did do this on the gen 4 and 5 motors with the head gasket thou
