Standard hiace manual gearbox behind high hp motor..?
Postby larryex » Sat Apr 11, 2009 9:47 pm
Hi guys. Anyone had much to do with standard Hiace boxes behind 1UZs or JZ motors?
I have had a 2JZGE (auto) and now a 1JZGTE (auto) in my one for some time now. At the times of these conversions the parts required to keep the van manual were very dear (bellhousings, flywheels, etc) but now they are a lot cheaper I am contemplating putting her back to manual again. The 2JZ NA motor was happy with the auto box, but this JZ GTE motor could do with a manual. My question - have any of you lads had a standard manual Hiace box ( what are they anyway, a W52 or G52 or something?) behind a Lexus v8 or a supra motor; have they lasted and handled it? I have seen on Youtube the odd hiace with a 1UZ and manual box, (usually doing circle work) but a 1JZ with the wick wound up has a fair bit more power and torque then these, so unsure it would take it. Of course the only prob with the van is that only a standard van box will work - converting a floor shift W58 or R154 to rod change for use in a van.. bit tricky. Any experiences or ideas helpful.
Cheers, Chris
larryex
Postby 99gtt » Sun Apr 12, 2009 11:20 am
depending on your model , but both my vans have r154's factory standard
SOON TO BE 500 HP
99gtt
Postby larryex » Sun Apr 12, 2009 2:40 pm
Is that right ay? Well my van is an older 93 RZH103, but the gearbox I have to use is out of a 2001 5L diesel Nz new Hiace, Interesting!
larryex
Postby NZ_AE86 » Sun Apr 12, 2009 4:31 pm
Done a couple with G5# boxes and they are good. Although you can break anything! Pipers is a G53 box and he has not broken it so maybe they are FOOLproof!
Some vans have the R15# boxes which are supposed to be stronger.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Sun Apr 12, 2009 5:23 pm
NZ_AE86 wrote:Done a couple with G5# boxes and they are good. Although you can break anything! Pipers is a G53 box and he has not broken it so maybe they are FOOLproof!
if thats not an advert for toyota gbox toughness i dont know what is! 8O
Postby larryex » Sun Apr 12, 2009 6:21 pm
Yeah well Nick thats right, if Nob cant break it.. It should be ok.
Anyway long story but it will be the box in MacIvers van if I do it.
larryex
Postby NZ_AE86 » Sun Apr 12, 2009 9:28 pm
Check on the id tag and if it is a R15# then it will be good. If it is a G5# then it should be ok.
Current rides;
1986 Levin GT
NZ_AE86
Postby NZ_AE86 » Sun Apr 12, 2009 9:32 pm
Mr Revhead wrote:
NZ_AE86 wrote:Although you can break anything! Pipers is a G53 box and he has not broken it so maybe they are FOOLproof!
You are not wrong there! I did give it one secret touch that may have helped but I still though it would have passed away long ago!
For those who don't know the gearbox in question is in a 4WD Hilux (1999) which I put a 1UZFE into about 5years ago. Since then it has been towing rally cars around the country and been given total death with no problems!
Current rides;
1986 Levin GT
NZ_AE86
Postby Distrb » Sun Apr 12, 2009 10:57 pm
its the rear diffs piper has trouble with :lol:
Distrb
Regular Poster
Users browsing this forum: Google [Bot] and 24 guests
