Fuel starvation at start up.
Postby Rick » Tue Apr 14, 2009 10:03 pm
If my car has been sitting for abit and I try to start it, it will only start when the fuel pressure is built up enough during cranking. My car has a fuel surge tank setup and aftermarket fuel regulator.
I think whats happening is the fuel is draining back into the tank when the car is turned off.
I thought about simply installing a switch to prime the fuel pumps before start up?
Has anybody had this problem or is this normal?
Postby jakesae101 » Tue Apr 14, 2009 10:06 pm
wondering the same thing with my 4agze standard just the first start of the morning takes a bit to crank over then starts up no problems rest of the day just
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby l1ttle_d3vil » Tue Apr 14, 2009 10:38 pm
jakesae101 wrote:wondering the same thing with my 4agze standard just the first start of the morning takes a bit to crank over then starts up no problems rest of the day just
could be your cold start injector and/or cold start injector timer that's shagged?
mine used to take a fair bit of cranking to start and needed throttle.
have adjusted the cold start and now starts alot quicker with no gas...
Postby jakesae101 » Tue Apr 14, 2009 10:41 pm
hmm interesting was thinking cold start injector how do i ajust it?
jakesae101
Postby finx » Tue Apr 14, 2009 10:44 pm
you cant adjust the cold start injector itself. the ecu controls that via the thermo time switch which adds extra fuel when cranking over on cold start up.
this could be either stuffed or it isnt connected.
daily: ep71 turbo s 2et 90hp atw 15.5sec 0-400m (stock) current 5efhte + ct9b on 6psi, 13.7@158km , torque steer??
nothing sounds like a 2stroke engine on the rev limiter
finx
Postby l1ttle_d3vil » Tue Apr 14, 2009 10:53 pm
jakesae101 wrote:how do i ajust it?
get a link g3 :lol:
you can check the resistances of the injector and timer to see if they are within the right specs, have a search on the net - i've got them somewhere so i'll have a look and post them up if i find them.
Postby MAGN1T » Tue Apr 14, 2009 11:21 pm
It's more than likely one of the aftermarket parts that's not performing.
Some aftermarket FPRs seem to leak and drop pressure over time. Maybe hook up a pressure gauge to see what's happening.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Re: Fuel starvation at start up.
Postby NZ_AE86 » Wed Apr 15, 2009 2:31 pm
Rick wrote:If my car has been sitting for abit and I try to start it, it will only start when the fuel pressure is built up enough during cranking. My car has a fuel surge tank setup and aftermarket fuel regulator.
Does the fuel pump 'prime' when you turn the ign on?
You should have full fuel pressure when you begin to crank if everything is working as it should.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Rick » Wed Apr 15, 2009 5:12 pm
Pumps only turn on when you start to crank the engine over.
Postby RomanV » Wed Apr 15, 2009 5:21 pm
Perhaps hardwire the fuel pump to be on before you crank, and see if it cranks over any quicker that way?
I know that with distributorless cars they can potentially need to do up to a full 360 or 720 degrees of engine cranking before it knows when/where to fire a spark plug? What setup does the GZE have, dont they run coilpacks or something, or still dizzy?
Postby jakesae101 » Wed Apr 15, 2009 5:23 pm
they run coilpacks normaly there should be a prime singnal to the fuel pump before the car is cranked over
jakesae101
Postby rollaholic » Wed Apr 15, 2009 5:41 pm
yeah the pumps should be running on IGN
i would have thought your surge tank overflow would be at the top (ie shouldnt be draining back into tank while its sitting)
Postby Rick » Wed Apr 15, 2009 6:20 pm
No prime signal, I just followed the factory wiring diagram, fuel pumps are off the "open circuit relay"
rollaholic wrote:i would have thought your surge tank overflow would be at the top (ie shouldnt be draining back into tank while its sitting)
The surge tank overflow returns back into the main tank but Iam talking about the return from the fuel regulator near the fuel rail, which also returns back to the main tank.
Postby escortman » Wed Apr 15, 2009 7:24 pm
would have thought it would have wanted the pumps run on ign
4x4 toyota blizzard offroader
escortman
Postby cedwards » Wed Apr 15, 2009 7:40 pm
I may be reading the wiring diagram wrong but the way I interpret it they are connected to the ignition.?
The fuel pump relay is triggered through the efi main relay and G-R wire which I assume goes to ground?
Therefore should prime when you turn ignition on.
What keeps the pumps running when you are not cranking ie: when engine is running if not so?
cedwards
Postby gepsk8 » Wed Apr 15, 2009 8:03 pm
escortman- would have thought it would have wanted the pumps run on ign
no, so if u crash and have a fire the pump will keep fueling it, not gud idea.
finx- you cant adjust the cold start injector itself. the ecu controls that via the thermo time switch which adds extra fuel when cranking over on cold start up.
no, the cold start injector get signal via start circuit, and the big gay brown plug at back of head(when cold).
MAGN1T- Some aftermarket FPRs seem to leak and drop pressure over time. Maybe hook up a pressure gauge to see what's happening.
all fuel system drop pressure when pump arent running
Rick- u run a surge tank setup, when u dont drive the car offen the fuel will return to main tank, so ur high pressure pump is running dry as low pressure pump has topped up surge tank yet
i suggest put a spung return switch so u can prime the surge tank first before starting
O272754663
gepsk8
Postby escortman » Wed Apr 15, 2009 8:10 pm
gepsk8 wrote:escortman- would have thought it would have wanted the pumps run on ign
o i meant like wen 1st goes to ign for 3secs or something, thats how my stinger works
escortman
Postby NZ_AE86 » Thu Apr 16, 2009 1:59 pm
The GR (Green with red trace) wire on the relay goes to the ecu and goes to ground through the ecu - it will prime when the ign is first switched on and will then run again when the ecu sees the expected RPM signal.
Your fuel pressure reg. might bleed a little but if you prime system is working then you should have no problem.
You do not need a prime switch unless something is wrong with your wiring as it will only do what Mr Toyota decided to have the factory ECU do.
You should put a gauge on to confirm that fuel pressure is you issue but either way you should ensure your wiring is right.
Current rides;
1986 Levin GT
NZ_AE86
Postby cedwards » Fri Apr 17, 2009 2:31 pm
NZ_AE86-The GR (Green with red trace) wire on the relay goes to the ecu and goes to ground through the ecu - it will prime when the ign is first switched on and will then run again when the ecu sees the expected RPM signal.
Is your ecu then sending the appropriate ground "signal" on first ign on? should be easy to test. I assume it is working fine once running (seeing expected RPM signal) otherwise you'd stall.
Otherwise why not move your reg return and plumb it into surge tank? Then if Both your low pressure IN and fuel return are plumbed at the top of the surge tank (eliminates either siphoning the surge dry) you should always have a full surge tank which should give your low pressure plenty of time to catch up once engine is idiling. And your high pressure should always have fuel to start.
:D
cedwards
Postby rollaholic » Fri Apr 17, 2009 7:21 pm
just about every car i have ever driven primes the pump on IGN as mentioned
Users browsing this forum: Google [Bot] and 20 guests
