jakesae101 wrote:wondering the same thing with my 4agze standard just the first start of the morning takes a bit to crank over then starts up no problems rest of the day just
jakesae101 wrote:how do i ajust it?
Rick wrote:If my car has been sitting for abit and I try to start it, it will only start when the fuel pressure is built up enough during cranking. My car has a fuel surge tank setup and aftermarket fuel regulator.
I think whats happening is the fuel is draining back into the tank when the car is turned off.
I thought about simply installing a switch to prime the fuel pumps before start up?
Has anybody had this problem or is this normal?
NZ_AE86 wrote:
Does the fuel pump 'prime' when you turn the ign on?
You should have full fuel pressure when you begin to crank if everything is working as it should.
rollaholic wrote:i would have thought your surge tank overflow would be at the top (ie shouldnt be draining back into tank while its sitting)
gepsk8 wrote:escortman- would have thought it would have wanted the pumps run on ign
no, so if u crash and have a fire the pump will keep fueling it, not gud idea.
