Removal of AE111 Trueno Quarter Glass
Postby xsspeed » Wed Apr 15, 2009 12:21 pm
I have a guy picking this up tonight, so need to remove for car,
Is there anything I need to look out for when removing the glass, as from the looks of this diagram, there is just a clip/fastener and the glass just slots into place.
Steve
Postby xsspeed » Wed Apr 15, 2009 6:42 pm
Bump, anyone?
Am trying to get it out now, is harder than I thought with a stuffed arm
Postby Bling » Wed Apr 15, 2009 7:00 pm
Can't say i've taken one out, but they look to be well in there so it might be glued as well?
Should have put "buyer to remove" in the auction :wink: :lol:
Postby xsspeed » Wed Apr 15, 2009 7:15 pm
yeah, should of started an auction :?
it is well in there, have said come back on weekend, will give it a decent go. might try the other side 1st incase I smash it
Postby andyztouring » Wed Apr 15, 2009 7:53 pm
They are glued in,cut them out from the inside(remove interior panels first),mouldings etc are fitted into the glass first then bonded(glued) into the window opening.
andyztouring
Postby xsspeed » Wed Apr 15, 2009 8:30 pm
Cheers, just what I needed confirmed
Postby Bling » Wed Apr 15, 2009 9:58 pm
I'm guessing the car will be scrapped at some stage?
If so, use a grinder and cut around the window and hand them the window with 50mm of car frame still stuck to the window :lol:
Postby jakesae101 » Wed Apr 15, 2009 10:19 pm
there is a special tool if its glued in like windscreens thin wire used as a saw
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Stott69 » Wed Apr 15, 2009 10:55 pm
A good sharp craft knife will cut the black sealant stuff, might take a bit, but patients may be needed.
Image jzs147 Aristo money pit
Stott69
Postby xsspeed » Thu Apr 16, 2009 10:03 am
Lol actually thought of cutting the metal around the glass, but at this stage I am trying to avoid cutting the car, incase I can sell the shell to someone
I will go the craft knife route, always have success with windscreens this way (except for new ones)
Never had much luck with the wire and cork style 'saw'
Postby xsspeed » Sat Apr 18, 2009 2:16 pm
Well, that was a b*tch
Broke it
Postby Bling » Sat Apr 18, 2009 2:54 pm
Guts :(
Using the knife method?
Postby Rick » Sat Apr 18, 2009 3:19 pm
xsspeed wrote:Well, that was a b*tch
Broke it
I got one if you are interested.
Postby xsspeed » Sat Apr 18, 2009 3:21 pm
BZG|Bling wrote:Guts :(
Yeah thought I had it started to pry it a little bit and SMASH, spent a good 40 mins cutting it too.
Postby xsspeed » Sat Apr 18, 2009 3:22 pm
Broke it
If you wanna make $60 bucks pm me your number and I will pass it on to the dude
