W55 VS R154
W55 VS R154
Postby KE25-KP30 » Wed Apr 22, 2009 8:12 pm
Hey guys, just been doing a bit of searching on 1JZ manual options and there's the two main (cheap-ish) options, the W5* and the R154. I guess there's always the V160 or J160 (which one is it? Always skips me!)
Here's the thing, I already have a mint W55, so the price of that excluded, a niteparts bellhousing and flywheel combo is $1000 with the clutch kit on top of that. (That's if you get an auto to start with) and from what I've seen, R154's seem to be in the $1000-$1500 mark (or am I way off??) If that's the case, is it worth the few hundred more and just go for a R154? Or the other thing, are genuine JZ-W bellhousings and flywheels availiable for less than the niteparts bits?
Any ideas?
Cheers :D
KE25-KP30
Postby edwagon » Wed Apr 22, 2009 8:32 pm
You'll be very lucky to find genuine jz bellhousings and flywheels 2nd hand, and prices are likely to be at least as much as the niteparts items - and the niteparts flywheels are cnc machined steel too, so not really any comparison to factory cast junk!!
I ran a w55 behind a 220rwkw 1j in a jzz30 soarer and it was fine - I had skatey tyres and mellow clutch tho, which helped keep the box in one piece. They are getting close to their limit behind a strong jz, a late w58 would be better (also better ratios), but really It'll come down to how its driven.
R154s are stronger, and 1000-1500 sounds cheap to me. Be wary that you're not buying one with a 7m bellhousing instead of jz! Also keep in mind that the jz clutches for R154 were a pull clutch which are alot more mucking around (and $$) than the normal push type for a w5*
Whats it going in??
edwagon
Postby KE25-KP30 » Thu Apr 23, 2009 12:10 am
Oh wow, interesting! Good points there, I guess W boxes are a tonne cheaper to replace if the need does arise.
Not in anything, only hypothetical at this point :-) It'd be lighter than a Soarer or Supra tho and like you, would probably not have very grippy or wide tires on it.
Just trying to work through what I want to do and where I want to go!
Thanks again :D
KE25-KP30
Postby rollaholic » Thu Apr 23, 2009 8:04 am
do the M bells not suit JZ's? i've seen one or two trademe auctions that said they were the same
Postby strx7 » Thu Apr 23, 2009 12:06 pm
rollaholic wrote:do the M bells not suit JZ's? i've seen one or two trademe auctions that said they were the same
Definitily DIFFERENT
Postby Mr.Phreak » Thu Apr 23, 2009 12:24 pm
strx7 wrote:Definitily DIFFERENT
+1
Mr.Phreak
Postby 4bid1n gt4rc » Thu Apr 23, 2009 11:58 pm
i was just wondering the same thing about what box to use but behind a 2jzgte think ill go with a r154
1993 2JZGTE ARISTO
1979 TOWNACE VAN ON 17'S
4bid1n gt4rc
Postby postfach » Fri Apr 24, 2009 10:53 am
Clutches for the R154 aren't really more expensive than any other similar clutch, I bought an exedy sports tuff 5 puck clutch for mine for the same price I paid for my 3 puck I used on the W58 (~$750)
postfach
Postby FLAWLES » Sun Apr 26, 2009 12:59 am
just a point to remember there are two diff types of r154
external linkage
and
internal linkage
external linkage ones come out mostly in jzx100/110 chassis cars and have the gear lever placed back alot further
if a r154 came up for 1g i would be very concernd about its state, lol or the dude doesnt know what he has haha
i think from memory they suffer the same issues as the v160's but i could be wrong
1500 is still dam good buying
but yea flywheels and clutch set ups are rather $$$$
FLAWLES
Postby NZ_AE86 » Sun Apr 26, 2009 5:39 pm
FLAWLES wrote:i think from memory they suffer the same issues as the v160's but i could be wrong
What are the issues?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby FLAWLES » Sun Apr 26, 2009 7:22 pm
i have herd syncros
but like i say i could be real wrong here
due to the fact i have only " herd " and not " seen "
i know there is a release bearing upgrade for the r154 box's tho
FLAWLES
Postby Lloyd » Sun Apr 26, 2009 8:43 pm
1st gear thrust bearing/washer was the only issue I know of with them
Users browsing this forum: No registered users and 26 guests
