the ae111 (4afe) sometimes the foot pedal is abit sticky.
Mainly just the first couple of times you use it on a trip.
is there something that needs to be greased or lubed?
DriftSpecStarlet wrote:Lol Grease the pivot pointup under the dash, also check your cable that runs through your engine bay see if its catching on anything, check the part where the cable meets your Throttle Body that could be dirty as hell if you havent got a clean engine bay.
Quirky wrote:Its a very common problem for sticking pedals on the 4afe. Both of the Corollas I had equipped with the 4afe had sticking pedals, symptom of a dirty throttle body.
