ezy10s wrote:interesting you mention boots as i have done two on the rear half shafts in two days at puke.
Whats this circlip under the boot trick one of you mention?
Ill be replacing all three sets of shafts with new boots and they will be in the spares box at all outings from now on.
Bazda wrote:
When you install the boot and about to clamp the boot to the shaft, slide a failry large split pin (can be anything really thats around 30mm long and 3mm tall) under the boot so it sits in between the shaft. Then do up the clamp. This leaves small breathing holes.
I cant upload pics here at work.
GH wrote:I'm in, need some time in car
GH wrote:
HA HA I have a AE86
cat007 wrote:GH wrote:
HA HA I have a AE86
Oh great - so you'll be over taking me sideways..... lol
Bazda wrote:
He wont even be a blur, we wont even see him pass us!
He owns the 3sgte ae86 with the flares etc and got the fastest time overall at the last superlap.
oh.... LMAO
Bazda wrote:My car is still not ready. Having oil pump issues. Hope to have it fixed by the weekend, still gota run in the new engine and then do a high boost road tune.
cat007 wrote:Bazda wrote:My car is still not ready. Having oil pump issues. Hope to have it fixed by the weekend, still gota run in the new engine and then do a high boost road tune.
I have taken turbo/wastegate/manifold off, and have yet to cut rotate and re-weld the new wastegate flange on. Replace water lines that have overheated and cracked due to lack of heat shields. Make heat shields for brake master cylinder, clutch master cylinder and for some water lines and the oil drain, and for the oil feed. Source gasket for manifold to turbo.
Oh yeah and get 2 new hard lines made up from master cylinder to proportioning valve. And hope that my brake caliper adapters are done in time, and when they are, measure and get a new fitting put on the end of my my SS braided brake lines. Then bed the brakes in.
Oh yeah and pull gearbox out, rip it apart, put in missing shift link pin thing, make up and press in a new sleave for gear stick selector thing
AND I'm still going on the 1st! So you're little "oh boohoo I have an oil pump and tune issue" is NOTHING! haha
Bazda wrote:
My oil pump issue is bigger than all your issues. Your issues are easy to fix.
My issue is we dont know why they keep stuffing up
