by KinLoud » Sat May 16, 2009 12:37 am
I know that the 4wd transfer case will NOT bolt on if you use an unmodified 3sge block! (Gen3 3sge into ST185)
Pretty sure the 3sge block has extra bosses and extra rib on the intake side that get in the way of bolting on the transfer case.
Adydas had to grind about 10mm off the extra rib to make room.
Also I don't think the 3sge block has the boss where the oil feed bolts onto.
Got your PM, I do have a gen2 3sgte block. It's half promised to someone... I will check if he still wants it.
Ken
Auck
021 408 863
