CT26 compressor CFM
Postby Akane » Sun May 24, 2009 11:03 pm
rollaholic wrote:akane is talking about scottie putting the supra version on his 3S, not you
(i think)
Thanks for clearing it up.
Postby Scottie » Tue May 26, 2009 5:59 pm
Akane wrote:My guess is that you made a custom manifold for the turbo, since as far as I know it won't bolt up to the factory manifold. Why not choose a better and more common turbo instead of the Supra CT26?
It more or less bolts up. You have to make a something for the wg actuator for mount to and clock the comp housing around to suit(or get the st165 machined to fit the comp wheel). But you use the same manifold. ST185s might be different, as the manifold has the turbo sitting in a different position compared to an st165 due to different I/C sizes.
Scottie
