3S bellhousing question
Postby evil_si » Thu May 28, 2009 9:37 pm
Ive been told a while ago but can any one confirm that a
3ct diesel rwd bellhousing will bolt upto a 3SGE
simon
evil_si
Postby KinLoud » Thu May 28, 2009 9:50 pm
running a 2c bell behind my gen3 3sge
Postby rollaholic » Thu May 28, 2009 10:16 pm
i think frost is using a hilux bell of some sort behind a 3S
probly the one you are talking about
Postby strx7 » Thu May 28, 2009 10:39 pm
if you see it on the following list, it has the same bell housing pattern
1C 2C 3C
1S 2S 3S 4S 5S
1VZ 2VZ 3VZ 4VZ 5VZ
1MZ 2MZ 3MZ
1GR 2GR 3GR 4GR
Postby frost » Fri May 29, 2009 1:33 am
to ad to that list. 2y 3y 4y
im using 3y because it puts starter motor on the intake side. only because i need to make rood for turbo manifold. 3sge you can use any of the listed above.
Postby strx7 » Fri May 29, 2009 7:35 am
i thought a Y series pattern was close (some bolts match) but not exactly the same???
Postby evil_si » Fri May 29, 2009 8:37 am
awesome cheers guys.
I have heard the Y series needs one of the top holes slotted and fits perfectly
evil_si
Postby KinLoud » Fri May 29, 2009 11:11 am
viewtopic.php?t=57191&highlight=bellhousing
S/C bellhousing
Y bellhousing - see top right bolt hole is closer to centre of bell
Postby KinLoud » Fri May 29, 2009 11:15 am
STRX7 - you say all these are the same...
1C 2C 3C
1S 2S 3S 4S 5S
1VZ 2VZ 3VZ 4VZ 5VZ
1MZ 2MZ 3MZ
1GR 2GR 3GR 4GR
I THINK.....
That for the VZ V6 family 3 of the 4 holes are perfect... the other one is way off?
Looking for pics on MR2 forums
Ken
Auck
021 408 863
Postby strx7 » Fri May 29, 2009 11:54 am
i bolted a 1vzfe camry manual box to a 3sfe engine without a hitch
Postby KinLoud » Fri May 29, 2009 1:18 pm
ahhhhhhhhhhh, see....
never believe everything you read on the internet
I think I have a 3VZ? hilux to R150 bellhousing somewhere
If I find it I will take pics and/or put a C/S plate on it and take pics to put in the FAQ
Ken
Auck
021 408 863
Postby strx7 » Fri May 29, 2009 1:48 pm
in saying that there is no saying that the box i had wasn't originally off a 3S and had been bolted to a 1VZ with 3 bolts not 4.........
Postby frost » Fri May 29, 2009 11:42 pm
strx7 wrote:i thought a Y series pattern was close (some bolts match) but not exactly the same???
yeah one of the top holes is about 5mm off. no biggie, i used a round file and it was perfect in two minutes of filing. soft alloy is easy to fix. also i dont need to shave the bellhousing down like the others do. only needed a slightly fatter spigot bearing.
Postby KinLoud » Sat May 30, 2009 6:49 am
- what motor/flywheel?
- what starter motor did you use?
Just asking because I know the Y starter location is closer/different offset?
Ken
Auck
021 408 863
Postby strx7 » Sat May 30, 2009 8:57 am
Ken, I'm pretty sure a lot of the 2Y townace/3Y hiace, use the same starter motor as the ST150 coronas with 1S/2S they would use the same ring gear too
Postby frost » Sun May 31, 2009 12:44 am
ken.
gen2 motor and flywheel with ring gear flipped
3y bell housing and 3y starter with a 5mm spacer on engine side of backing plate to bring it in line with ring gear. it tucks up under the intake manifold very nicely.
Postby evil_si » Mon Jun 22, 2009 12:21 pm
is the altezza 3sge different to earlier 3sge's?
reason being i have a W56 with 3C bellhousing and it will not bolt up, the bolt pattern is very different.
evil_si
Postby strx7 » Mon Jun 22, 2009 4:49 pm
is it out of an estima or something with the engine over on its side?????? just tip the 3S right over........ :P
Postby evil_si » Mon Jun 22, 2009 5:09 pm
yea it is out of an emina van discovered that earlier,
even with the bellhousing sitting at 90' to the engine only 4 bolts line up,
so on the hunt for a bellhousing that will fit if you know of anything let me know,
evil_si
Postby KinLoud » Mon Jun 22, 2009 7:42 pm
frost wrote:gen2 motor and flywheel with ring gear flipped
yeah thought about that when I did my conversion but the bevel ends up on the wrong side of the tooth (trailing edge vs leading edge of tooth)
I just ended up hand cutting bevels very carefully!
Only 4 main bolts on the bell line up with the block - the smaller holes on the alloy sump have to be slotted to match with the bellhousing holes... Originally the bellhousings had separate braces that bolted between the bell and the block.
Don't know about estima setup but engine on big slant probably cocks everything up
Ken
