engine warning light AE101 4age 20v
Postby headshotnz » Tue Jun 16, 2009 6:23 pm
Hey guys,
Im absolutly stumped, my engine warning light is on,
My car is stuck in limp home mode,
Iv replaced the TPS, the water temp sensor and the AFM as had spares.
I have put it in diag mode but the engine warning light hasn't blinked at all.
From what i read it should blink twice to report no error's. But it doesn't do this either.
Is it a faulty ECU?
When the car is really cold, then engine warning light will be on, it will be quite hard to start (As if its a carbd)
Then after about 5 seconds of splutteryniss it will be fine, until operating temperature then be back in limp home mode with the engine light back on.
Any help would be great!
Cheers every one.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Alex B » Tue Jun 16, 2009 6:25 pm
Stuffed ECU very common in AE101, take it out, take the lid off and see if the caps are bulging/stuffed.
Postby matt dunn » Tue Jun 16, 2009 6:28 pm
Yeah I agree, faulty ECU, and common problem.
I used to have some for sale but have run out.
I may be able to repair it for you if you get stuck.
Matt
Postby Adamal » Tue Jun 16, 2009 6:31 pm
Worst case I've seen on one was the whole PCB was corroded! :?
Postby headshotnz » Tue Jun 16, 2009 6:35 pm
Cheers for the fast reply, have got the ecu, have had a quick look, but i have an untrained eye, am getting my mates dad to have a look tonight when he gets home, will report back once i find out.
:D :( lol
headshotnz
Postby Adamal » Tue Jun 16, 2009 6:39 pm
This should give you an idea of how to recognise a popped or pregnant capacitor:
And see the 2 at the bottom? Thats how they should look.
Postby headshotnz » Tue Jun 16, 2009 6:42 pm
Adamal wrote:This should give you an idea of how to recognise a popped or pregnant capacitor:
Thanks alot mate, old motherboard much? whats it for? old p3 or celeron or something? :D
Will let you guy's know in about an hour all take some photos while im at it.
headshotnz
Postby matt dunn » Tue Jun 16, 2009 6:44 pm
Never noticed that before on any of the one's I've seen.
Another way is open the ECU up and smell it?
Smells like fish = Faulty.
And that's serious too.
Not all have visable signs until you remove the capacitor to check the board.
Postby AceSniper » Tue Jun 16, 2009 6:56 pm
yeah most iv seen the top of the cap looks ok, but down around the base of the cap there can be corrosion visible
AceSniper
Postby headshotnz » Tue Jun 16, 2009 8:37 pm
Theres some pictures guys, some may be better then others.
So i uploaded all of them.
On a update, i was holding it at 1.5k and it sounds lumpy cam, burns lots and lots and lots of fuel, my poor wallet is taking a hit, iv spent about $70 bucks in the last 5 days :(
Also, it was flicking on and off. it doesnt normally do this. strange.
headshotnz
Postby matt dunn » Tue Jun 16, 2009 10:14 pm
put another ECU in it.
Postby headshotnz » Tue Jun 16, 2009 10:53 pm
matt dunn wrote:put another ECU in it.
Thats easy to say, but i dont have another one, well i have 2 auto ones, but they dont work with the manual loom. other wise i have to buy one...
Got quoted $125 from the wreckers.
headshotnz
Postby levinguy » Tue Jun 16, 2009 10:59 pm
i dont know if the plugs will plug into the ecu, but if they do the ecu should work if you bridge the starter inhibitor switch (makes the car only start when in park)
levinguy
Postby matt dunn » Tue Jun 16, 2009 11:00 pm
levinguy wrote:i dont know if the plugs will plug into the ecu, but if they do the ecu should work if you bridge the starter inhibitor switch (makes the car only start when in park)
no, way to different to even plug in on them.
Postby Alex B » Tue Jun 16, 2009 11:27 pm
Thats cheap. Few years ago mate got quoted one for $500.
Postby rollaholic » Wed Jun 17, 2009 8:07 am
will be $200+ to get it repaired without mates rates
Postby headshotnz » Wed Jun 17, 2009 4:04 pm
Got a quote for $150 so will be repaired tomoro :)
headshotnz
Postby Crampy » Wed Jun 17, 2009 4:20 pm
Where are you?
I've got one you can try out to confirm if it is the ECU.
Crampy
Postby 1I1 » Wed Jun 17, 2009 5:21 pm
He's in wellington
TRD Clicky >>Here
1I1
Postby AceSniper » Wed Jun 17, 2009 5:33 pm
wow @ prices
the caps are worth like 4bux :/
AceSniper
