BZ Touring wheel and tyre fitment
Postby brunch » Sun Jun 28, 2009 7:50 pm
I have searched the forum with no good answers for this so thought I'd post..
I just bought a 1997 Corolla BZ Touring wagon (AE101) that has 15s with 205 50 15 on it.
They rub at the back, and on one side of the front on full lock.
I think it may be more an offset issue with the wheels, but even then, there does not seem to be much clearance behind the wheel.
I want to get some 16s or 17s on there but will they rub?
Has anyone else with a BZ done the same?
Thanks for your wisdom!
brunch
Postby Bling » Sun Jun 28, 2009 7:51 pm
Lowered car?
Where abouts does it rub? Be specific
The front is probably just a plasitc inner guard, just don't turn to full lock or find out where its rubbing and (if its the plastic part) chuck a cable tie through it and tie it further from the wheel
Postby brunch » Sun Jun 28, 2009 8:19 pm
Yeah I'm not worried about the front, its the back.
As far as I am aware it is standard height.
It rubs at the top point on the inner of the guard.
So if this is the guard (see below) then it rubs at the top point.
___
/ 0 \
Obviously guard rolling would fix this, but it shouldnt rub in the first place?
Just keen to hear what others have experienced.
brunch
Postby Bling » Sun Jun 28, 2009 9:10 pm
Got a photo?
Doesn't sound like the wheels are the right offset. You should be able to fit 205s in there. Pic would also confirm if its lowered or not.
Postby matt dunn » Sun Jun 28, 2009 9:10 pm
we run 17 x 7's and 205's on our BZT, but it's AE111 shape.
On standard springs and no rubbing.
Postby brunch » Sun Jun 28, 2009 9:24 pm
BZG, the best photos I have are on the trademe link for the wheels for sale
I think you've got access to TM?
http://www.trademe.co.nz/Browse/Listing ... =226868981
Photos 1 and 5 are the rear wheels.
Matt, what offset are the 17s you are referring about?
Thanks guys, appreciate your help.
brunch
Postby Bling » Sun Jun 28, 2009 10:15 pm
Well i'm stumped, shouldn't be rubbing on the top really..
Is it all the time or only if you cart around some chubbies? :lol:
Postby brunch » Sun Jun 28, 2009 10:20 pm
Haha haven't had any of those!
Umm its going over big bumps, reversing out of steep driveways onto the road etc.
What I'm really wanting to know is whether 205/40/17s (with a 40-45p offset) will fit with no more rubbing? There are a few sets I've got lined up...
I know trial fitting is the most guaranteed way, but a pain in the....
brunch
Postby Bling » Sun Jun 28, 2009 10:34 pm
Go to a local mag shop and ask if you can try one on?
Hard to know why its rubbing from the pics.
Postby brunch » Sun Jun 28, 2009 10:34 pm
True, will do.
Was hoping I wouldn't have to, but looks like its the only option.
Thanks for your help mate, much appreciated.
brunch
Postby matt dunn » Sun Jun 28, 2009 10:36 pm
Not sure of the offset,
but the only time I get rubbing is when we (over)load it up when we go away at new years.
Basically hit the bump stops and just rubs on the guards at the same time.
and it just rubs on the bolt at the corner of the bumper.
Postby brunch » Sun Jun 28, 2009 10:39 pm
Ah ok. Good stuff. Looks like I should be ok with the 17s then.
Cheers for the photo!
brunch
Postby tsoob » Mon Jun 29, 2009 1:13 pm
brunch wrote:Ah ok. Good stuff. Looks like I should be ok with the 17s then.
hey man i got a few set of 17's here going cheap in that fitment,, sounds like u need to roll your guards as well. come by the shop and see me ill be able to explain all the fitment issues to you.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby brunch » Mon Jun 29, 2009 1:26 pm
Cheers mate I might just do that. Hopefully you're open till 5.30?
brunch
