lucasthefallen wrote:EDIT: dont get a link, similar money will get you into an autronic ecu and they are far better. as regards to injector control and tune-ability, also the datalogging is heaps better.
lucasthefallen wrote:with out being rude, i dont want to get into a debate about what ecu's are the best etc.
strx7 wrote:if your vehicle sees road driving time, then basically the more you pay, the nicer it will be to drive.
At the end of the day, a locked dizzy and a blow thru carby set up will make a car run, and can pull consistant 8's down the 1/4 mile, but drivability at different rpm/load/boost/vacuum/temps etc is what it all comes down to.
2jayzgte wrote:While we are on the subject of ECU's how much does the resolution of the processor tell how good a ECU is I no the Apexi Power FC's were 20 20 and the HKS F-Con V Pro is 32 32 who can explain what this is means with regards to how good a ECU is ?????
Lith wrote:That would mean that with this ECU the same amount of fuel and timing will be used for any revs between 0 and 2499rpm and 0% to 25% load, and as you could imagine the amount of air the engine flows and the way it behaves with it would change SUBSTANTIALLY through that rev range so it means there is a lot of guesswork at play.
Users browsing this forum: No registered users and 32 guests
